photos are coming out with a blue tinge. Out on the harbour where the water is a greeny blue and the sky grey to blue, all photos seem to have a blue tinge. ISO is 100. Photographed some trees and these also have a blue tinge.
Check the white balance settings. If the photos where taken in the high midday sun this is the high UV content in the air. Set you white balance to Cloudy and see what that does. Also fit a UV lens to the front of the lens if haven't already.
the flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was...
(More)
the flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was dropped a short distance from my hands. just want to know what i can do myself. if anything
if the picture is taken vertically in EOS 400D SLR, there will be a black shade appearing in right...
(More)
if the picture is taken vertically in EOS 400D SLR, there will be a black shade appearing in right side of the image. This issue was not there earlier. In recent times it started happening. It works fine if the picture is taken horizontally.
I have the same problem but I get this Err 99 message. It tells me to turn off the camera or...
(More)
I have the same problem but I get this Err 99 message. It tells me to turn off the camera or re-install the batteries.It sometimes works and sometimes it doesn't Also I am in holiday in Thailand. Did the heat and humidity have anything to do with it? It never happened to me the last year when I was in Thailand and Cambodia.
error message "the built-in flash's auto pop-up was obstructed. turn the power switch to off...
(More)
error message "the built-in flash's auto pop-up was obstructed. turn the power switch to off and on again" I've done that with no luck. Any ideas what to do?
I'm getting an error msg sayign shooting is not possible and to utn power switch to on and off again...
(More)
I'm getting an error msg sayign shooting is not possible and to utn power switch to on and off again and to re-install the battery, I think some moisture may have affected the machine, what can I do to solve this? Many thanks in advance Rachel
