Toshiba Satellite A105 PC Notebook
Problem for Toshiba Satellite A105 PC Notebook
What can i do if my laptop having a no display
By vic_lazaro on Nov 05, 2009
what can i do if my laptop having a no display problem?
please help me.
Best Solution
posted on Nov 05, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Hardware  Expert
Rating: 95%, 2483 votes
itz may b caused frm many internal hardware cause, like the battery(main/cmos); ram; sm section of the system board; ccfl; inverter circuit; or even the lcd....
howevr, before proceeding to complex test to verify the current status of ur laptop, at 1st all u need is to put on the laptop to charge for atleast 4hrs..(the gauge status may show u a pseudo process)..
if u r a professional, remove the ram(s) from itz slot(s), gently rub itz connector teeth using a rubber to remove carbon or oxide formed if any..
connect it to a external monitor n see if display is coming..
check the internal system battery to b above +3v..
so itz always better to hv supervision..frm ur system admin/vendor/good or authorised service center....
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
Somewhat Helpful)
Azraelsrl
Rating: 91%, 420 votes
First you need to test if the problem is hardware or software: try to enter the BIOS by pressing on F1, F2 or Escape. If you can't then it's a hardware fail, take it to a shop. If you can then in the boot order put the CD first. Next download and burn a Linux Live-CD like   PCLinuxOS - http://www.pclinuxos.com/ - and boot from it.
If the screen is black, again go in the BIOS and check that the local screen isn't disabled. If it isn't then it's a hardware problem.
If in the Linux disk all is OK then it's a software problem: connect your laptop to another monitor and boot into windows; right click on the desktop, click Properties and in Settings input the correct resolutions and, for the one on the laptop, select the Primary option.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A105 PC
Questions and Unsolved Problems for Toshiba Satellite A105 PC
Do you recommend Toshiba Satellite A105 PC Notebook?
Answer
Answer
fn plus F8 key malfuntioning and can not connect new laptop M550 to AT&T Broadbrand. New... (More)
Answer
I can´t turn it on. I´ve had it checked and everything seems to be OK, although I... (More)
Answer
I am so frustrated. This program feels like a scam to me. I have uploaded the pop several times;... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , GA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
