The current status is "operational" -- packet filtering is being used so that "outgoing" IP-addresses originating from a network are required to be IP-addresses that are valid within that network.
Hi all, Here is my problem at hand: using a windows xp pro pc connecting to SMB server 2003 via RDC...
(More)
Hi all, Here is my problem at hand: using a windows xp pro pc connecting to SMB server 2003 via RDC does not show my local IP printer and thus I am unable to print from the remote server. here is what i have done: Removed and reinstalled the exact same drivers Made sure both printers are shared with the same name (that is on the remote pc and local) Enabled (checked) printers under the local resources tab in RDC options. I have done the above over and over each time using a different lpt port on the server but still when loged in via RDC session I do not see my local IP printer. These settings did work but for some reason windows just decided that it should stop this remote printing for whatever reason. I am stuck and do not know what else to try to make this prining work, any help would be greatly appreciated. Thank You in advance
