Apple iMac 17 Intel Core Duo 1.83GHz   PC Desktop
Problem for Apple iMac 17 Intel Core Duo 1.83GHz (Open Box, Limited...
Macintosh HD will open from
By reevecj on Nov 05, 2009
Macintosh HD will open from desktop icon but won't stay open. I can access all but applications files using finder but Macintosh HD closes when I click on applications. I recently transferred files from my G4 eMac and in error to the Intel iMac applications folder via an external HDD and a USB flash drive. Also recently I upgraded to OS 10.4.11 and upgraded all the iLife software. How do I get access to the HDD to remove the in error file?
Comments:
Nov 24, 2009
- G'day all and raptordrew, thank you for all suggestions. Each had some benefit for me with the problem, but none fully solved the problem. The solution,in the end, was dead easy. I upgraded the eMac to the same OSX level as the iMac, set the iMac in target mode connected it to the eMac and used it to remove all the earlier app. folders, that may have been causing the problem, restarted iMac and all the problems were fixed. Upgrading the OS system in the eMac proved to be very beneficial. Once again, thank you all for your help. Chris
Solution #1
posted on Nov 12, 2009
Not Rated)
raptordrew
Rank: Master
Rating: 93%, 7 votes
Sounds like you may have some permissions issues - I would suggest sticking in the OS disc that came with your iMac, restarting, and holding the "C" key when you hear the chime - this will make it boot off the CD. Once booted from it, go to Tools->Disk Utility, choose your disk, and do "Repair Permissions". Once that is done, you can quit the installer and restart. If that doesn't work, the next step I would recommend is running DiskWarrior, which is $99 - this is like an industrial permissions/hard drive directory repair disc, used by many professionals. If that doesn't solve it, you will likely have to back up your user data and do a fresh install of the OS from the discs you have. Good luck!
Was this helpful?
Yes
No
Popular Solutions for Apple iMac 17 Intel Core Duo
Questions and Unsolved Problems for Apple iMac 17 Intel Core Duo
Do you recommend Apple iMac 17 Intel Core Duo 1.83GHz (Open Box, Limited Availability, Limited Warranty, No Back Orders) (MA199LLAOB) PC Desktop?
Answer
Answer
i tried to download adobe flash and got this error: tn_19166
Answer
i have a acer desktop computer . we had a house fire and didnt think the computer got damaged . but... (More)
Answer
my new packard bell imedia S1710 keeps popping up a message saying not enough memory even when doing... (More)
Answer
I have a laserjet 1200 and it won't print it is telling me it is idle. How do I fix this.
Answer
where Ican I find the agp8x motherboard user's guide. I need conect the USB front cables and one DVD... (More)
Describe your PC Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
