On pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
