Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Repair guy says my york ecm motor is bur...
By stephen_chiu on Nov 05, 2009
repair guy says my york ecm motor is burned out and needs replacement. estimated cost with labor is $1000.00...any other options as I am out of work and on a very tight budget?
Clarification Request
Posted by nanbuenbrazo on Nov 05, 2009
can you give as the full specification of your ecm motor? and the details regarding to it?
Solution #1
posted on Nov 05, 2009
Not Rated)
ASK HANK
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 130 votes
if the inducer is bad it must be replaced. I would call around for prices - seems a little high. (have the furnace model and serial number when you call)
Comments:
Nov 05, 2009
- should have said ECM motor instead of inducer. ECM motors are very expensive. People don't know that when they buy these fancy new furnaces they will cost a fortune to repair when they break. Also be sure you don't have any warrenty left.
Nov 05, 2009
- also be aware that Luxaire and Fraser-Johnston are the same as York
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
on my window airconditioner I am constantly getting a thick ice buid up. I have cleaned the filters... (More)
Answer
I live in a manufactured home. When I turn on my heat on my amana it does not start.
Answer
I have an error code of CH 26 on my LG airconditioner 524AHN can you help me diagnose the problem.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
