Heaters
Problem for Heaters
Generic problem for all Heaters
Rinnai gas heater loud noise on ignition
By bubsbigbash on Nov 05, 2009
My Rinnai EnergySaver 557FTR gas heater makes a very loud fluttering noise on ignition about 75% of the time. I think it might be due to lack of oxygen because of the length of the flue (it is flued through the roof). Rinnai are being most unhelpful, and say that it is an installation problem.
Comments:
Nov 06, 2009
- Thanks Therinnaiguy, that's very helpful. Yes, we have had the gas pressure tested, and it's all okay. I am in New Zealand, and the Rinnai Flue Kit guide says we can have 8 metres of vertical flue (26 feet). We have less than that. So it seems to me that the problem is Rinnai, not the installion contractor.
Nov 06, 2009
Best Solution
posted on Nov 05, 2009
Very Helpful)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 87%, 473 votes
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Comments:
Nov 06, 2009
- Ok but did you take off the air intake pipe? If it takes care of the noise, replace the combustion fan motor.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks very much. Please see comments. " - bubsbigbash
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
goodman furnases reliability
Answer
best heater for a 5,000 square foot monolithic dome
Answer
I tracked the smell to an in wall vent/heater. That was he middle of the night so I turned all my... (More)
Answer
i have a 30 year old Farenheat model MCM15003 works like a champ, until now. i tor apart and found... (More)
Answer
On our sunroom walls we have two 3UG27D electric wall mounted baseboard heaters. They are controlled... (More)
Describe your Heaters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , IL
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
