Question about LG Electronics LRM-519 Digital Media Recorder
2 units have died. Possible power supply problem
Hard drive work. Display screen is dim. Have replaced the battery. No use. When turning unit on, fan runs for about 4 seconds, then stops. Operation won't go any further. Can't find anyone to work on this unit. HELP!!!
  • pdgsanjose Mar 18, 2008
    Similar problem, the display shown `Hello' then freeze there, the fan and hard drive don't even turned on.
  • beermiser Jun 25, 2008
    I had the same problem. The unit died after a power outage. Same symptoms - fan runs for a couple of second and dies; dim "Hello" on the screen. I sent it to LG for repair. They called and said lots of machines had the problem and they couldn't fix it - said they didn't make the part anymore (PNC or PCN card?). They offered to buy it back at a steep discount (depreciated purchase price over three years). I'm having them return it to me.
I know its a pretty basic fix, but try it before sending the unit into LG for the dreaded "cannot be fixed" or $69 story...
Open the unit, remove CMOS battery, start unit without battery, it should display "please wait" wait a couple mins, then unplug / replace battery and restart. Hopefully you will have the success that I did! (I doubt this fixes all your problems... however it most certainly fixed my unit that was stuck with dim Hello, then "DEMO" mode problem)
Best luck to all!
Posted on Sep 16, 2008
  • Anonymous Sep 27, 2008
    At this point, I was able to canabolize one unit to save another, the only problem is everyone is holding on to these DEAD units and want $200+ bucks for something that doesnt work. If I could find a stack of them that are dead door stops (as the manufacuturer is only offering $79 to buy the unit back), perhaps I could keep my one unit running on lifesupport...
    haha
I sent mine to LG with $69, this is the response I got "The LRM-519 sent to us for repair is needing a part 6871RP0801A which has been discontinued". It looks like we are all out of luck for repairs to this unit...
Posted on Sep 10, 2008
  • 4 Answers
I had a LRM-519 that would not get past a very dimly lit "hello" on the LED screen. I called tech support and was advised to make sure no disk was in the unit and turn off the power from the unit (not the remote) and unplug it from the wall outlet. While unplugged, hold down the power button for 30 seconds then plug it back in. This didn't work the first time, but after a few tries it worked for me. My unit hadn't worked for nearly 3 months prior to this. Good luck.
According to LG support, it would have cost $69 for labor plus parts to repair the unit. The main board/power board is $40.
Posted on May 06, 2008
6ya staff
SOURCE:
Drive will not turn on.
Step 1:
Just the drive or the computer ??
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm Testing & replacing the PC's power supply http://www.youtube.com/watch?v=hbNxhvm0czs
Mar 14, 2013 | Computers & Internet
Hp pavilion elite m9517c desktop pc wont power
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Aug 29, 2012 | Computers & Internet
Computer not turning on when switched on. Has turned on twice in many attempt.
test your psu power supply unit if the units fan is not working the psu is faulty
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Sep 15, 2011 | Acer (56.04200.H22) (5604200H22) 200-Watt...
Desktop power turn on but turn off within 5 secs or so, what could be possible problem, not beeps of errors PSU fan turn on aswell.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 10, 2011 | Packard Bell (190169) Power Supply
Cant operate bios after reformatting the unit
If you cannot operate the BIOS, the best way is to reset the CMOS battery which require a very good technician to tear down the unit. Here are the steps:
Turn off laptop
remove cables and battery
Press and hold power button for 5 secs.
Remove screws in the edges of the laptop
Remove Hard drive, Optical Drive and Power supply fan
Press the CMOS battery (circle shaped silver coating) upwards so that it would disengage and put it back in...
Put back the Hard drive, Optical Drive and Power supply fan
Put back screws in the edges of the laptop
Put in cables and battery
Turn on laptop and the BIOS will be reset successfully...
Jan 09, 2011 | ASUS A8HE-4P017C (90NNVA4115384CAL301) PC...
Why won't my PC boot up? I turned it on one morning, went to the restroom and when I came back, the screen was black and the green light was no longer blinking. Now when I turn it on, I can only hear the...
How long does the fan run for? If it dies as soon as you switch it on it could be the power supply or if it is an older laptop the battery.
If you know anyone with the same laptop try swapping the supply.
If the fan continues to run after powering up the unit it is probably the motherboard. It is possible to replace but I would take it to a local IT shop as other internal units could be damaged.
Aug 14, 2010 | Acer Aspire 5100 Notebook
Computer monitor don't work at all.
So basically your monitor's power supply system died.
Nothing much a non-technician could do about it.
Get it repaired, if under warranty, get a replacement before the coverage duration expires.
Jun 07, 2010 | Computers & Internet
Gateway MT6451 Does not turn on
Probably the mainboard or flaky power supply.
I'd start by replacing the power supply. Buy one you can use in a new machine, though... or "borrow" one from another machine.
Mar 11, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Acer Aspire 5100 problem
You don't want to hear this I know, but your symptoms are very much like those of a computer in which the motherboard or processor has died. It is defnitely not the hard drive as you would still get a display and be allowed to go into Bios even if the hard drive was totally out of the computer. And missing memory would result in bios beeps indicating a faulty bios configuration, but all of that requires that the motherboard and processor be good. If they are not, you have the situation you are speaking about.
Aug 25, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Lrm 519
Had same problem. My fix was to repair power supply.
On power supply board replace capictors C18 & C36.
2200mf 10v rated 105C
Dec 25, 2007 | LG Electronics LRM-519 Digital Media...
LG Electronics LRM-519 Digital Media Recorder Logo
492 people viewed this question
Ekse
RONALD CARTER JR
