Question about Durabrand DB1200 CD Player
No wireing harness
I was switching the cd player out of one car and into the other when the factory wire harness fell off and broke. i like the cd player but for a new harness durabrand wants $25. i was wondering if anyone had ane extra one laying around send me price thanks
  • 1 more comment
  • Marky B1967 Feb 20, 2008
    I need to locate a wiring harness for this stereo. I'm in MA. anyone know who can sell me one? I can't order online, I don't have a credit card. HELP!
  • gouldman7 Sep 10, 2008
    I also would like to find a wiring harness for the DB1200. Please contact me at gouldman7@aol.com. Thank you
  • Anonymous Nov 15, 2008
    dont know how to hook up the remote wire
    Problem Solver:
  • 14 Answers
Ok everyone,
If your looking for an answer for this I hope this helps.
The connector on the back of the Duraband receiver is the same design as the connector used on
most computer power supply connectors for the motherboard.
You can cut off the old connector for the PC power supply, and then cut off as many extra pins as
needed so it will fit into the back of the receiver.
Only thing is you will need to re-label each wire according to your old harness that may be damaged.
If ANYONE has the existing harness, and would like to tell us which pin goes to which color, this would be great. Most of the receivers have a color code on the case bottom, but it doesn't identify which color corresponds to which pin... please help...
Randy
Posted on Oct 05, 2008
I have a 1985 ford ltd crown vic I just bought a aftermarket radio but the wiring isn't the same its still has the factory radio and wiring kit how do I change them in order to use my new cd player
You can go to best buy or a stereo shop they have wiring harnesses and fit kits for aftermarket CD player the wiring harness plugs into the stock wiring harness the u have to match the wires to the cd play
Mar 28, 2014 | Cars & Trucks
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
Wire harness to switch from stock stereo to cd player will not fit the wires that are supposed to? so what wires are the speaker wires
Not sure I understand your question. Did you buy a harness adapter for GMC, or are you trying to just cut the connector off the factory radio and solder it to your CD player? If the latter, below is the color code for your factory wiring.
1994 GMC Sierra C1500 Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 20, 2010 | 1994 GMC Sierra
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
96 dodge caravan radio wires
see an auto sparks ,or take to a local radio fitting shop ,no good telling me here because colours of wires can vary between manufacturers of both the radios and the vehicles
Aug 07, 2009 | 1996 Dodge Caravan
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Wiring diagram for my radio/cd player in my truck
do not cut off the factory plugs you can go to any electronics store and buy the harness that will plug into the factory harness and give you wires to connect to. all of these harnesses will have the wiring diagram in them and run about $25
May 02, 2009 | Car Audio & Video
Trying to put a cd player in a 2002 sable ls
i think its factory fitted ?? so you might not have the wiring loom pre installed
Apr 02, 2009 | 2002 Mercury Sable
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your car.........to install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Durabrand DB1200 CD Player Logo
265 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
