Question about Microsoft Xbox 360 Console
I need to start Xbox Live. But it says It cannot get a connection
I cannot connect my new x-box to my network
  • Anonymous Jan 08, 2008
    i have the same problem but mine is a regular xbox .i dont kno if it's because the ethernet cable isn't the right size or what.
A wireless router 100$
Posted on Jan 18, 2008
Get a wirelss router
Posted on Jan 04, 2008
3 Suggested Answers
SOURCE: xbox live not working
XBOX SHOW E68
Posted on Jun 27, 2008
  • 34 Answers
SOURCE: xbox live party
your nat type is strict you can change this by opening up your internet explorer go to tools then internet options and make the needed changes
Posted on Jul 12, 2009
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
I can not connect to xbox live
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Video Game Consoles & Games
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
X-BOX
Jan 23, 2011 | Computers & Internet
Im trying to get my xbox live nat type to open i have the linksys wrt54gx2 router with srx 200 please help my by giving instructions on fixing this problem.
X-BOX
Jan 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
The dsl is red and when it turn green i still can connect to xbox live, but when i try to connect my xbox says i need a higher mtu is that possible to change from a laptop
X-BOX
Jan 21, 2011 | 2wire (1000-400108-001) Router
I need to know how to open my nat type for xbox live
X-BOX
Jan 10, 2011 | ASUS (SL1000) Router
I dont know how to connect to x box live
you will need a wifi connet and xbox 360wireless networking adapter for this to work.
Sorry
Dec 30, 2010 | Microsoft Xbox 360 Console
Im trying to connect to get live and when i clicked on join xbox live it said cant be connected to xbox live
Make a new user profile and try to create and x-box live profile that way, ours got wiped once and we got the same message and that is what we had to do.
Nov 10, 2010 | Microsoft Wireless Network Adapter Xbox...
My xbox 360 wont connect to xbox live and ive tried everthing
things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
Apr 22, 2010 | Microsoft Xbox 360 Console
I have tried to connect to xbox live
you need to make sure you have enabled ICS, Internet Connection Sharing. To do so, you go in to the internet settings (found in the network sharing centre)choose your net connection, click 'view status' and then click properties (the first of three buttons at the bottom, properties, disable and diagnose) then once the window pops up, there is a sharing tab, check the box that states 'allow other users to connect to this computers internet connection' after that simply dis connect and re connect and the new settings will be able to be used once you do a xbox live network test. Good Luck.
Nov 04, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
