RCA 20F514TD 20" TV
Problem for RCA 20F514TD 20" TV
Rca 20F514TD blue screen
By nicoleroach2 on Nov 05, 2009
blue screen says "no signal". i tried the input button, the analog/digital button, its on channel 3 and still is not working.
Solution #1
posted on Nov 05, 2009
Not Rated)
johnnydiode
Rank: Guru  RCA Televisions & Videos  Expert
Rating: 93%, 248 votes
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Was this helpful?
Yes
No
Popular Solutions for RCA 20F514TD 20" TV
Questions and Unsolved Problems for RCA 20F514TD 20" TV
Do you recommend RCA 20F514TD 20" TV?
Answer
Answer
my tv turns on and off by its self and switches from tv to dvd by its self
Answer
rca trufalt 20" television keeps cutting on and off
Answer
when entering the menu screen,how do you choose an item
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
