Question about Symphonic ST419E TV
WF2707 back cable and video cables won't give me pictures but the front game video cable will show the picture
  • 93 Answers
SOURCE: video game, hear sound but no picture
try the menu button on the front of the set, this normally will get you to the proper mode
Posted on Sep 06, 2009
0 characters
1 Points
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Standard (CRT) Televisions
My JVC AV-32432 tv unresponsive
Can you switch between tuner and inputs? If not then you may have a number of problem i.e;input selector or controller i.c. If you can switch to tuner(cable) and do not get picture then you may want to check your tv cable connection at the back and along the line (splitters) or your tuner may be defective
Nov 17, 2009 | JVC AV-32432 32" TV
Video game, hear sound but no picture
Sep 06, 2009 | Symphonic ST420FF 20" TV
Rca tru flat tv has a red picture
Is your video input (from cable or satellite or fiber optic, etc.) coming from a coaxial cable, a component cable (red, green, and blue connectors), or an RCA cable (yellow connector for video)?
If you can, try an alternate input method and see if that makes a difference. Does it happen when watching DVDs or tapes, or when playing video games, or just when watching television?
Mar 13, 2009 | RCA TruFlat 27F520T 27" TV
13" Orion TV having display issues...
There may be a short in the video game system, which could have fried something in the input circuits. And of course, make sure you have your TV cable plugged in, and the TV set to cable position before determining that the TV has an actual problem. Unfortunately, some functions may only be on the remote of course.
Jan 02, 2009 | Sylvania 6427TE 27" TV
No picture for game
get it checked out.
Apr 12, 2008 | Sylvania 6427FF TV
Was distorted picture, now no picture
ok,try to resolder or reheat the main board of your tv.from microprocessor,the video chroma section,the crt board...if reheating is not the solution,replace either the microprocessor or the chroma or crt driver.
Oct 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Symphonic ST419E TV Logo
23 people viewed this question
Top Symphonic Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Symphonic Standard (CRT) Television Expert? Answer questions, earn points and help others
