Question about Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 paper jams and almost no ink
I've got an Epson AcuLaser C1900 printer, which has been working fine for quite some time. Then I moved and took the printer with me. During this period, it hasn't been operating for about two months and it was stored in a much colder environment.
Now I constantly get paper jams, ofthen when the page is already more than 80% out of the printer (when printing from the smaller tray). When printing from the big tray, the jams are much earlier in the paper flow.
When the page does get out, it is unreadable. you can see a faint colouring where something should have been printed, but it is impossible to make out what that should have been.
I've been hunting for stuff in the printer (which is unlikely, since it was working before) and I have no clue what the reason could be for those problems or even if they are related.
All help would be greatly appreciated!
Cheers,
Tim
  • 2 more comments
  • timjhl Jan 05, 2008
    thanks a lot for the reply!
    Ther results that I'm seeing now are much better. The only remaining issue is that the printer seems to start printing about 5 centimeters/2 inches from the top of the page (there is a "grey" line there (not printed). I see this behavioureven when printing a status sheet. Any idea what the reason might be?
    Thanks a lot,
    Tim
    Thank you for your help! The paper-shifting isue isn't resolved yet, but I made a giant leap forward thanks to your advice.
    Cheers,
    Tim
  • sunseeker888 Feb 05, 2008
    Hi
    I have same problem as TIM. Moved the printer to a different location, and it was not used for 3-4 months. Now, it prints as if there ain't no color (ink although , I have replaced all the toners a few weeks ago). Paper keeps jamming after nearly 80% of printing. Any color on a page, the printer jams. Printing word doc just in black, are always 5-6 cm below margin, even in print preview it looks ok.
    I have a big mistakes, I have contacted the technician at Epson, online chats. they suggested to remove the photo conductor unit
    and the transfer unit. They told me to give a good clean with cloth which i did. when I inserted everything back. now I am getting another problem.
    1. K toner cart out.
    K toner is new, was working before tips from epson.
    I contacted epson again, they said to take the toner out and re insert again. I did a few times.
    The problem persists, now I can't even use the printer to even to print in black.
    MTspace
    from your tips
    1. Open the cover below the paper path roller.
    2. With a clean dampened cloth, wipe the pickup roller
    Where is the pickup roller? I know where is the path roller, i can not find a pick up roller.
    Please help. K toner cart out
    and where is the pickup roller
    Regards
    Irwin
    Is it i have to flip the 2 green levers, just on the top when i open the AB cover? to get it .
    I read through the reference guide, they did not mention anything about pick up roller?
    Hi
    I have inserted a video, for pickup roller? am I right, it's that small roller under paper roll cover, I am pointing at?
    Thanks
    Irwin
    Scholar:
  • 103 Answers
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Posted on Jan 04, 2008
  • Terri Bates
    Terri Bates Jan 05, 2008
    The page length and margins could be set incorrectly in your application. Make sure that you are using the correct page length and margin settings in your application.
    But since you said the status sheet prints that way too, the printer settings most likely need to be adjusted.
    You can apply basic settings automaticallly by using predefined settings, or if you need to change detailed settings, make the settings manually.
    Follow these steps to customize your print settings:
    1. Click the advanced button in the basic settings menu, then click more settings. A dialog box appears.
    2. Choose color or black as the color setting.
    3. Choose desired printing resolution from 300 dpi or 600 dpi with the resolution slider bar, then make other settings.
    4. Click OK to apply your settings and return to the basic settings menu. (or click cancel to return to the basic settings menu without applying your settings.)
    To save your custom settings,
    1. Click the advanced button and click save settings on the basic settings menu. The custom settings dialog box appears.
    2. Type a name for your custom settings in the name box, and click save. Your settings will appear in the list to the right of the automatic button in the basic settings menu.
    It could also be that you are using an overlay setup. If you cannot figure it out from the above methods, start a new problem sheet and add a screen shot to the post.
I need a software for Espon Aculaser C1900
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Dec 08, 2011 | Epson AcuLaser C1900 Printer
What does error code EO23 mean on an Epson Aculaser C1900
this error refers to a misalignment of the carousel, i have one that randomly does it at the moment, i also have a replace black toner even though the toner is full, i'll get back to ya when i find a fix, the service manual says it can either be the 2nd motor, clutch or sensor, but in my case all three are working fine.
Oct 07, 2009 | Epson AcuLaser C1900 Printer
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Epson c1900 jam b
Paper is jammed inside the output path cover or fuser unit
Please go to this link so you can see on how to take the jammed paper out and look for Jam B (Cover AB)
http://support.epson.ru/products/manuals/000447/alc1900qr_e.pdf
Feb 05, 2008 | Epson AcuLaser C900 Printer
K toner cart out, Epsom C1900 Aculaser color printer
i had the same problem as you i feel very upset with epson that they did not help you for me what i had to do is lay my printer on its side with the door to the toner facing you taking the toner out looking down into the bottom you will see a little plastic block wist it half way till it stops then reinsert the toner becarefull not to drop it in that shoud be fully fitted inside then put the unit back the right side up and start the printer up this shpuld fix your problem ok thanks
Feb 05, 2008 | Epson AcuLaser C1900 Printer
Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Jan 29, 2008 | Epson AcuLaser C900 Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
The Cleaner Pressure Flapper Solenoid it dead or dying. You can try moving it by hand to see if you can prolong it, but basically it needs a new one. Its a job for an engineer really.
See the image below for it's location.
Sep 17, 2007 | Epson AcuLaser C1900 WiFi Printer
Epson AcuLaser C1900 Printer Logo
774 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
