3 short lines about 10 cm in midle of the sceen(red yellow green)
---now 1 thin same color about 10 cm on midle of right sideMy problem are
You can't post conmments that contain an email address.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, one or more colors won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary. And the power supply fuse links to the power pacs checked and replaced as needed.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills. After the above repairs are performed it may be necessary to perform the static convergence realignment procedure using the outer cross hairs as you mentioned, and realigning them.
set the convergence that should take care of the double lines, as far as too much red that sounds let your red bias is being driven to hard behind the speakers and the cover board you will find 3 knobs one of the knobs I believe the one on the left but it is labeled anyway that needs to be turned down ever so slightly and I mean slightly if you go to far up then it will shut the TV off and it may or may not come back on. so be careful when doing this
There is an alignment mode that you can get to. You must take off the back cover and look for the alignment switch I suggest that a tecnician do this because he has the propper tools and knowledge. If just an allignment is all it needs it should not cost that much. You have to try not to move this type of tv around because it is very sensitive and the slightest bumb can send it out of wach.
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Bad solder connects in convergence circuit...a solid fix is to
replace STK392-110 convergence IC's with upgrade STK394-160
Part # CZ 01341... you need two.....or buy kit # X480295 ( one )
Look for any damaged resistors near IC's.............T.
My problem are
