Question about RIM BlackBerry Pearl 8100
Bluethooth heandsfree Hi, Does anyone know how to make a blue-tooth hands-free device to be used as a headset device so I can listen to music and such? Phone is a Blackberry Pearl 8100 and the blue-tooth hands-free is a Motorola H300. Thank you
  • Anonymous Jan 23, 2008
    Well, that was the first thing I tried but it didn't work. It just doesn't send the signal to the bluetooth device ( no problems when in call mode though ). The sound comes through the phone but sounds very muted and distant. I guess its just some kind of compatibility issue, since the bluetooth headset is not stereo. Anyway, the bluetooth drains my battery so fast, so I'm not gonna use it to listen to music through it :). Thanks for trying though
It should just be a manner of turning on the media player on the phone and pressing the button just the left of the roller ball (it's got 7 dots on it) and sending using bluetooth while the headset it on.
Posted on Jan 22, 2008
6ya staff
SOURCE:
What is Blue Tooth and what does it do?
https://en.wikipedia.org/wiki/Bluetooth
another wireless system
used to exchange data between bluetooth enabled devices
used for linking hands free units in cars to mobile phones
used to connect mobile phones to speakers to listen to music
Jul 18, 2017 | Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i use on my phone??
Here is the link to manual:
http://southerntelecom.com/emersonsupport/downloads/EM227.pdf
The manual will explain everything you need. from pairing to wearing.
Good luck :)
Apr 17, 2011 | Emerson EM227 Bluetooth Headset
I want to listen to music on my phone with my bluetooth headset
iIn order to listen to music on your blue tooth headset you first must pair them to your phone,To do this you first must turn the power to blue tooth to on in your phone menu,then you will have to put your blue tooth device into discovery mode,most bt manufactures use the power button for this feature,when turning your headset on continue holding down the power button for 6 to 10 seconds and a light should stay on ,thus putting your bt device into discovery mode thenfrom your phone you can search or add new device,it should recognize the device and ask for a pin or pairing code.Most manufactures use a factory 4 digit pin pairing code,they are as follows 0000,1234,9999,or 1111,once your code is entered they should pair,then you will be able to use your blue tooth device to listen to music.glad to be of assistance
Feb 26, 2011 | Radio Communications
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
How to connect by bluethooth in Lexus 350 to blackberry 8520
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
I try to connect my HTC M200 bluethooth headset with my Samsung S-M5230 mobile. The mobile can not find the headset. I tried it with another bluethoot, and it worked. The headset also use to be working...
is this the first time that you're going to pair the phone and the headset? try to turn off both devices, turn on the blue tooth headset, try to press and hold the power button for 5 seconds until you see a solid led light on the headset, try to open the phone, open the phone's blue tooth then search the headset. If the phone is asking you to enter a code try to enter 0000.
Jul 06, 2009 | Samsung Cell Phones
Motorola H700
Is your HP Blue Tooth compatible? Check the specs for your system and see. If it does not say it has Blue Tooth compatibility then you can buy a rather inexpensive Blue Tooth doggle that plugs into one of your USB ports.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
RIM BlackBerry  Pearl  8100 Logo
114 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
