I have just purchased a 2000 Micra without the hand book. Any iders where i can get one for free or...
(More)
I have just purchased a 2000 Micra without the hand book. Any iders where i can get one for free or cheap
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the...
(More)
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the cooling! fan runs ok. Have got it half pulled to bits...problem seems to be in the cooling motor/ compressor if it has one!
Re: remove the heat sink fan wiring from a Gateway MX6920 laptop. I've found the disassembly process...
(More)
Re: remove the heat sink fan wiring from a Gateway MX6920 laptop. I've found the disassembly process suggested by Shhoo but there is no instruction for the fan especially how to disconnect the wiring. I have lifted the white plastic tab and removed the 4 wire connection, but I don?t know if I have broken the tab and when putting it back together, do I just insert the wires (with hook like end connectors) and pushing down on the plastic white tab? Thanks for your help. http://support.gateway.com/s/Mobile/Q106/BladeC/1009030ul.shtml
To diagnose this the fan relay is the place to test. The relay is conceptually two circuits. One...
(More)
To diagnose this the fan relay is the place to test. The relay is conceptually two circuits. One high current circuit and one low current circuit. The concept is that the temperature sensor tells the computer that the temperature requires the cooling fan to come on. The computer then either grounds the low current circuit or feeds it with voltage. This closed circuit then completes the high current side of the relay, which runs the fan. So your fan continues to run for one of two reasons. 1. If you find that the low current circuit is open (meaning no current flow), yet the high current side is still closed, then you have a bad relay. 2. If you find that the low current circuit is closed, it is because the temperature sensor is bad, causing it to tell the computer the engine needs cooling after the temp drops below the range when cooling is needed...Is this expensive to get repaired? I tried looking up cooloing fan relay at Advance Auto got no results does it go by another name?
