Question about Canon PC1061 Copier
Changed fuser now scanner head stuck
I changed the fuser on the PC1060. Now when the scanner head moves , it goes all the way to the right . It looks like it is still trying to travel even though it is out of room.
  • Mike1957 Jan 14, 2008
    I am having a similar issue with my PC1061. It was working fine and then suddenly it failed to scan. The bar will not advance across the glass nor does the scanning light come on. I took the glass off to see if there were any obvious problems. The slide bar is clean and well lubricated. The ribbon cable “looked” OK. I slipped the bar off the belt and hit the copy button. The drive seems to work fine as it ran in both directions of travel with little effort or obvious concerns. When I put the bar back on the belt, the scanning light came on and it traveled across the rails couple of times then returned to the home position. The next time, it moved off the left stop position and stopped about ½ inch into the left to right travel. The light did not come on and it “quivered” like it was sticking or hanging on something. Everything appears to be clean and not dragging when moving the bar by hand…suggestions? thanks
  • 52 Answers
Hi i am a certified Canon tech on this copier. the problem you have is due to the scanner cable that runs from the top of the scanner to the main board in the back of the machine. what happens is when you take the scanner unit off to get to the fuser screw holes the cable should be removed from the main board under the rear panel with alot of screws. some people when they put the scanner unit back on they dont watch the position of the cable and when the unit slides back to open the cartridge door the cable is pulled part way out of the board connecter. the first thing i would do is to remove the back cover and chech the connector for the scanner cable to see if the cable is in all the way. also sometimes i have found that some one has pinched the ribbon cable damaging it underneath the scanner and replacing it with a new cable took care of the problem. the cable cost around $20. hope this helps.
Posted on Jan 05, 2008
Paper Jam always comes up whenever I turn the printer on. I checked THOROUGHLY, no paper at all!!!
Could also be the carriage stuck. Try to activate the change-ink button, and see if the print heads move over. If they do, unplug the printer from the wall, and then see if you can move it gently across from right to left.
If it's hard to move, try a little (1 or 2 drops) sewing machine oil in the metal shaft, move heads back and forth a couple times, then plug in again.
Mar 04, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
I have a hp color laserjet 2840 printer, it is showing scanner 5 please send the solution. thanking you,
Welcome to Fixya
It's a problem with the scanner unable to "see" its home sensor. The home sensor is a black & white film strip stuck onto the flatbed glass, just above where the scanner head homes. The printer needs to "see" the two little black 1mm square bumps in the white area. When the scanner head "homes", as it just disappears under the plastic it should move left and right as it looks at the home strip. If it keeps going and chatters at the right-stop it didn't see the home strip. Clean under the glass unplug all of the wires and get a can of air spray and spray the leads and the adf plug in too.
Let me know if you need further assistance.
Thank you for using Fixya!
Mar 26, 2011 | HP LaserJet 2840 Printer
Scan head is stuck in path and will not reset
I had the same problem. I disconnected the scanner from the PC. restarted my computer. Shook my scanner a little bit while PC was rebooting (or maybe a little slap) and when PC was rebooted), i plugged my scanner back and it recalibrated automatically.
May 21, 2010 | Canon CanoScan LiDE 500F Flatbed Scanner
The scanner bulb is stuck all the way over to the right. I have turned the machine off and on several times to no avail. What is my next step?
Does the scanner head try to move? Look at it closely when you power it on. Look at the belt that pulls the scanner back and forth - is it broken?
You may have to have the scanner replaced.
May 06, 2010 | HP LaserJet 2840 Printer
Where is the serial number on a Canon Pixma MX870?
The serial number is located on the guide for the print head holder. Open the cover, as if your going to change the ink. To the right of the print head holder (where the ink goes), on the guide that moves the holder back and forth, there is a white label with the serial number. The number starts with four letters and ends with five numbers.
Mar 28, 2010 | Canon Office Equipment & Supplies
Scanner error 5
Try this one open up the scanning lid, use a small allen wrench and pull the screw at the left side of the frame that holds a 1 inch wide by 12 inch long piece of glass. pot ur finger inside the housing and begin to roll the gear/rubber belt to move the scanner bulb assembly towards the left side as far as you can go. Then, turn the machine off and on.
If you are adept at printer repair, remove the right side cover, by removing the two screws in the hand hold area. pull the cover out at the bottom, using the handhold area, it will pop quite loudly. Once you get the cover off, you will find a large sheetmetal box with a row of connectors across the top of the circuit board. You do not need to remove the sheetmetal box to access the connector I am referring to. The four wire bundle I'm referring to has black, yellow, blue and red wires going to it. It's pretty much in the center of the row of connectors Be sure it is secure.
If the connector is securely inserted and no pinched wires are observed, the next most likely cause for this issue is a calibration stip for the scanner head inside of the scanner top. There are no spare parts for that level of repair. Opening the scanner top to repair it is likely to let in dust or debris and you won't find much that can be done if the calibration strip has moved or delaminated. The scanner top will need to be replaced. I believe the part number for the scanner top is Q3948-60191 unless it's been replaced with a newer part number.
that shud work if it doest contact hp....
good luck
Jul 12, 2009 | HP LaserJet 2820 Printer
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Replacing fuser pc1610
Please let me know if there is a technical reference or service manual for the PC1060 (including Image Class D860) printers.
MXM450, Please let me know how to replace the fuser. I have spent an hour trying to get to the fuser but am not sure if it is from underneath the feeder assembly, or through the toner cartridge door.
Oct 04, 2008 | Canon PC1061 Copier
Canon PC1060
The fuser comes out the left side, not from the top of the copier.
Jun 20, 2008 | Canon PC1061 Copier
Canon PC1061 Copier Logo
106 people viewed this question
old marine
old marine
