Question about GE Profile Harmony DPGT750EC Electric Dryer
Bearings How do you lube the bearings?
Most bearings used on dryers are self lubricating, the metal used
in the bearing was impregnated with graphite for lubrication.
Posted on Jan 04, 2008
My bcm740b humidifier fan isn't moving. Advice
Your problem is that your fan motor needs to be lubed. The bottom bearing on the motor can be lubed by taking the fan tower off the base and turning it upside down. Using a flashlight, you should be able to see the "bottom" bearing of the fan motor. I usually just put a drop or two of Mobil 1 or some other synthetic motor oil on the bearing and let it sit inverted for a few minutes so the oil flows into the bearing. If you are lucky, this will be sufficient and your fan motor will start running again....If not, then the "top" bearing ( when sitting in a normal position) right under the fan blade will also need to be lubed...This will require disassembly of the fan tower so you can access the bearing with some spray lube, then reassembly of the tower which can be tricky so you don't break any connectors that keep the whole assembly together. Try the bottom bearing first and save the other one for the summer!
Jan 01, 2018 | Humidifiers
Heat fan noise too laud. How to fix it
you have to access fan at heater core under dash and either clean debris //lube bearings or if beyond lube replace fan motor
Jul 08, 2016 | Toyota Camry Cars & Trucks
Oreck sqeals on start and stop
Probably has a roller brush with dry or dirty bearings. If the roller is removed usually the caps can pop off (be careful no bearings fall out!) and then cleaned. I would use a DRY lube not oil. Use Silicone or powdered lube like graphite / lock lube.
Oct 06, 2013 | Oreck XL2600 Vacuum
Says to lube belt .did that but when the safety key is inserted still saying lube belt
You must LUBE the deck belt, every week, otherwise you will have a WORN deck belt and replace with the rollers bearing. Now LUBE with 100% silicones lube.
2) lube THE Rolleler bearings too.
RUN the software calibration for easy diagnose, and troubleshooting
God bless you
Nov 17, 2012 | Exercise & Fitness
Pro form 550s only runs for 1/2 second and shuts itself off!
This happen because the LACK of LUBE , you must LUBE every 5 hours aprox from use. The design shut down the machine for protection electronic. Now lube.mAYBE YOU have a WORN deck belt and need replace.
2) LUBE the rollers bearing too.
3) Test the main motor bearing and replace if necessary.
God bless you
Nov 15, 2012 | Exercise & Fitness
Treadmill making knocking noise
1)Please LUBE the rollers bearing very well.
2) Lube the deck belt very well, see the video,
3) Adjust the tension see the diagram.
4) Lube the rack and gear from elevation motor see the diagram and adjust the potentiometer, test the bearing from the elevation motor.
5) Test the bearing from MAIN MOTOR, and repair .
God bless you
6_14_2012_7_24_52_pm.jpg6_14_2012_7_25_14_pm.gif6_14_2012_7_25_40_pm.gif6_14_2012_7_25_59_pm.gif
Jun 13, 2012 | Exercise & Fitness
The cpu fan makes noise then stops. Is there any way to lube it? It's a TP23
Most fans like that you can peel away the label in the center and put light oil on the bearing and work the fan in and out lightly to get the lube into the bearing. It is best to replace though, as they are not reliable once you have to lube. The original lube has worn out and the bearing is scored adding friction.
Sep 17, 2009 | Computers & Internet
I had the same problem...
sealed bearings dont need lubed if you can see bearings they need lubed
Jun 25, 2009 | 2006 Kia Sorento
Lubing the bearings
Bearings of the type used in appliances like this require no lubrication. If they ask anything it's to remain clean and free of lint. Oiling this type of bearing actually ATTRACTS lint and hair.
Jan 04, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
132 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
