Question about Dell 3000cn Laser Printer
Keep getting 091-972 Insert Drum Cartdridge error..
Hi yall,
I have a Dell 3000CN printer and it's now not detecting the drum cartridge that I install in it. I've purchased a couple of new ones already and the message is still "091-972 Insert Drum Cartdridge".
It must be a sensor thing, but where is it and how do I fix it? Or if not fixing it at least fake-it that the printer thinks a drum cartdridge is in.
and I'm out of waranty so I can't call Dell without dishing out mucho $
Please help....
-issam
  • bandak Jan 04, 2008
    I tried the steps to Init NVRAM, but no luck still got the same message after turning the printer back on.
    -issam
  • bandak Jan 05, 2008
    Ninjakid, yeah the drum is in place and totaly "clicked", still no luck.
    Problem Solver:
  • 5 Answers
Try this
  1. Press Menu.
  2. Press Keep getting 091-972 Insert Drum Cartdridge error. - d_bottonb.gif until Configure appears, and then press or .
  3. Press until Maintenance appears, and then Keep getting 091-972 Insert Drum Cartdridge error. - d_bottonb.gifc="http://i.fixya.net/uploads/images/r_bottona.gif" alt="r_bottona.gif" class="h_miKeep getting 091-972 Insert Drum Cartdridge error. - r_bottona.gifsrc="http://i.fixya.net/uploads/imageKeep getting 091-972 Insert Drum Cartdridge error. - arrowbutton_sa.gifif" alt="arrowbutton_sa.gif" class="h_mi" /> .
  4. Press d_bottKeep getting 091-972 Insert Drum Cartdridge error. - arrowbutton_sa.gifmi until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Posted on Jan 04, 2008
  • ninjakid Jan 05, 2008
    Did the new drum click into place? Here is a quick list on drum replacement in case you don't have them.
    1) Remove the protective sheet from the drum cartridge.
    2)  To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
    3) Pull down the lever on the right to lock the drum cartridge in place.
    4) Close the top cover.
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Dell 3000cn color printer - black/grey line down right side of page. Is it the drum? How to check drum?
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
Jan 27, 2010 | Dell 3000cn Color Laser Printer
Dell 3010cn printer, says reseat drum contact support. I took drum out and put it back in but don't see anything wrong. It feels secure and I restarted the printer, but no luck.
Hello sir; Pull out the drum cartridge, look around the cartridge you will find a small memory chip, remove it, shoul d take care this problem.
Nov 28, 2009 | Dell 3010cn Laser Printer
Error 010-397 restart printer
I would Hold down the "Menu" and "Cancel" Button then for "Reset Printer" ,Turn Off the Printer remove the cartridges then reset them again. Along with the Drum Unit. Something is Not Seating properly
start thier first.
If I could be of further help or your in the CT area then contact us:
http://www.copierspluswwllc.com
Oct 02, 2009 | Dell 3000cn Color Laser Printer
HELP!!!Toner cartridge jammed in school Dell 3000cn printer.
To rotate the carousel of the printer and not use the front panel do the following. Remove the drum; place it somewhere away from light. Leave the top open where you removed the drum. Close the front door. By closing the front door, you have depressed the locking mechanism that locks the carousel in place. Now using both your left and right hand and using even pressure, rotate the carousel (from the top of the printer) to the position where the toner is at. If the carousel makes any kind of clicking/grinding noise then it is still being affected by the locking mechanism, I would not suggest continuing. If you do not exert even pressure when rotating it this way, the carousel can become canted (twisted) and then would need to be replaced..
Mar 02, 2009 | Dell 3000cn Laser Printer
Error Code 004-332
try unplugging it for about 10 minutes and starting it up again... that hopefully will reset it.... have you found out what that error code is
Robert
Jan 29, 2009 | Dell 3000cn Color Laser Printer
Dell 3100 CN replace drum cartridge
No. There is no reset as there is with some units. This unit actually knows via a smart chip in the drum unit if it has reached EOL ( end of life ).
Jun 19, 2008 | Dell 3000cn Color Laser Printer
Trouble Printing Pictures
Hi
All you need to do is reset the printer to the factory settings, follow the instructions manual for dell 3000cn steps.
Print the Gradation [ESS] Test Print On the Printer
To print all four 20% toner test prints, perform the following step:
Power off the printer.
Hold down the up and down arrow buttons on the printer and power the printer on.
Press the down arrow button until Test Print appears and press the button.
Press the down arrow until Cyan20% [ESS] appears and press the button.
Press the button. The test print will print.
Press the Cancel button.
Press the down arrow until Magenta20% [ESS] appears and press the button.
Press the down arrow until Yellow20% [ESS] appears and press the button.
Press the down arrow until Black20% [ESS] appears and press the button.
STEP: Clean the contact points on the drum cartridge and the right side of the 3000cn-series / 3100cn printer.
To clean the contact points on the drum cartridge and the right side of the printer, perform the following steps:
Unplug the power cable.
Pull to open the front cover, and then lift to open the top cover.
Raise the lever on the top right side of the drum cartridge
Grasp the drum cartridge by the handle and lift up and out
Using a clean, dry, lint-free cloth, wipe the contact points on the drum cartridge
Clean the right side of the drum cartridge.
Using a clean, dry, lint-free cloth, wipe the contact points on the right side of the printer
Insert the drum cartridge.
Close the top and front covers.
Plug in the power cable.
Power on the printer
This should resolve the issue
Nov 08, 2007 | Dell 3100cn Laser Printer
Dell 3000cn Laser Printer Logo
698 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
