get 3 short beeps on start up tried different memory graphics card and still wont work,can u help
Comment posted on Jan 06, 2008
tried what u said and its still doing the same thing
right got no beeps no (god nos why) but now i have no signal when i start the pc
checked caps etc and everything seems fine,tried holding insert key down but still the same problem,i have tried different graphics card and onboard graphics but sill the same.i dont have a spare psu,plus i cant get my fat fingers in to take heatsink off to check it lol
Comment posted on Jan 07, 2008
tried another psu and now i am back to beeping even tho i aint touched the ram,starting to think the board is faulty
Try resetting the bios to defaults by clearing the cmos.
First switch off at wall and remove power leads. The push on button to discharge capacitors on board.
The jumper will be located near the bios battery and chip usually at the bottom right of motherboard. Move the jumper to the clear position and leave for a few mins. Then put back into normal postition and start pc up.
If that fails to clear it then repeat but remove the battery from the motherboard too and wait longer.
Hope that sorts it for you?
Just a long shot but try holding the "insert" key down on keyboard during boot as that used to work on some of the socket A boards i owned in the past.
Was there anything funny happening before this started? Have you had a good look over the motherboard to check for damaged compenents or bulging/leaking caps? Quiet a common problem on older boards
http://www.badcaps.net/
example are shown there of what your looking for.
Do you have a spare psu you could try?
Rating Locked! (?) brews has rated this solution as Not Rated
Thank You!
Was the solution helpful?
Show your appreciation by commenting on asrock k7s41gx motherboard:
