When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Comments:
Nov 05, 2009
- Try removing the program you installed, and then print it out again.
That's what I would do.
That will solve your question, of Adobe.
Good Luck.
Nov 05, 2009
- Glad to hear, that at least you are able to print a half decent picture. :0). Now, did you say you WERE using Epson Genuine Cartridges? That is a must !!! Also, Maintenance, Nozzle, Head & Alignment have to be done.
When I had that problem, I went thru 8 cartridges of ink, in cleaning alone.
Finally, after all that, my final conclusion was Epson would not work with Generic Ink !
Good Luck and pls let me know how it turns out.
Nov 05, 2009
- I'm glad I was able to help you.
After all, that I've been thru with this Epson, No wonder, I'm an EXPERT ! hahaaha.
No matter what, Epson, is still the Best for Pictures. (Even though, the ink cartridges are high.)
Please rate me if you are happy.
Good Luck Again.
