Question about Sony STR-DE345 Receiver
PROTECT FLASHING
HI I HAVE PROBLEM WITH MY DE 345 THE PROTECT KEEPS FLASHING CANT GET IT DO ANY THING HELP ME WHAT DO I DO
  • maret Jun 03, 2008
    My Sony STR DG510 receiver the Protector light is flashing and keeps turning the power off, how to fix?
  • Anonymous Aug 15, 2008
    protect sign flashing
    Genius:
  • 1,694 Answers
The protect circuit is doing it's job....probably the amplifier
output stage is shorted.....have a technician check it..make
sure any / all bad connects are soldered when chassis is out
for service......................T.
Posted on Jan 05, 2008
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
Protect flashing
es posible que un canal se ha dañado por lo que primero daño el fusible con la sobrecarga y posteriormente se daño el canal. es necesario se revisen las polarizaciones de los transistores para determinar el canal dañado,es seguro que el daño se encuentra en uno de los frontales.
Mar 21, 2009 | Sony STR-DE345 Receiver
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
Whirlpool AWG 345/4 error code E 06
after you have done a manual drain of the water what is left in ie pipe and bucket, Disconnect pipe at waste and remove round cover plug from lower left corner of machine blow down pipe this gets all muck /blockages out ensure you put somthing at machine end to catch any thing that comes out. Also ensure pipe is free of any objects which may have moved down pipe ie buttons coins. I had 4 buttons jammed in. sorry about the names i have given to parts on machine as i am a vehicle tech. hope it helps
Jul 30, 2008 | Washing Machines
CANT DOWN LOAD SONGS ON SANSUI MP3 MODEL SAN0012
I had this problem, but with Shuffle on and Hold off, I was able to update the player's memory.
Jul 09, 2008 | Audio Players & Recorders
Protect Flashing Sometimes
Dust the cabinet out with one of those cans of "dust off" compressed gas and make sure you have PLENTY of ventilation around the amp.
Feb 24, 2008 | Sony STR-DE345 Receiver
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Subsidy password
try entering "0000" it usually gets set as the defualt password unless some one set one when they were messing with it, if that works go in ti youir options and de-select the password protect option. good luck
Apr 24, 2006 | Motorola Mobility RAZR V3
Sony STR-DE345 Receiver Logo
284 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
