Question about Epson TM-U220PD Matrix Printer
My TM-U220PD driver was broken during the last flood here in the Philippines. Can you help me find the driver for it? Been into the EPSON site but all I found was drivers for TM-U220A/B/C/D - which i think, different from PD. THanks guys in advance
    New Friend:
Give me your email i will send you the driver for it... email me at [email protected] so i can send you the driver.
Posted on Jan 05, 2010
  • 4,472 Answers
Http://www.bioticaindia.com/tm-u220pd.html
This driver should help you.
Thanks,
Lee
Posted on Nov 05, 2009
SOURCE:
I need a printer driver for Epson TM-U220PD receipt printer for XP
http://www.posmicro.com/RECPRINTERS/EPSON/EPSON%20DRIVERS.htm here you go if it works let me know via a message or thumbs up if not i will continue to help you
Mar 16, 2011 | Epson TM-U220PD Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
Where I can find driver of printer Epson TM U220PD for Windows7 ? ? ?
If there are any you'll get them here
https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?url_jsp=http://www.epson-pos.com/
Aug 19, 2010 | Epson TM-U220PD Matrix Printer
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Nov 17, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD Matrix Printer Logo
351 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
