my 650 flashes vaccum condenser i turned it off and did then turned it back on. a day later it flashes the same massage again does it have a reset or is there something else i need to do
Good day, Cleaning the condenser is what the correct term should be. To vacuum many times does a poor job. I use either a compressed air tank with a hose, or else a push-pull vacuum cleaner with the hose and a crevice tool attachment on the end to blow the condenser clean.
Can create a mess at the time, but the condenser will be clean, and the purpose is to protect the compressor.
I came home one day to find the freezer had quit freezing, and the temp was 52 degrees. I can push...
(More)
I came home one day to find the freezer had quit freezing, and the temp was 52 degrees. I can push the button to display a lower temp and after 15 seconds returns to the 52 degrees or whatever it feels like going to... Why does it not stay at a freezers temp?
After ice maker was professionally repaired there is condensation on the back of the fridge, behind...
(More)
After ice maker was professionally repaired there is condensation on the back of the fridge, behind icemaker and under center rear panel. Water is dripping and pooling on the floor. Insulation missing?
There is water pooling on the floor of the refrigerator below the bottom crisper drawer. There is a...
(More)
There is water pooling on the floor of the refrigerator below the bottom crisper drawer. There is a hose behind the drawer that is full and leaking. Should this be full? What is the hose for?
