Question about Dell Axim X51v Pocket PC
What went wrong?
When I turned the power button onto my pocket pc, the password window opened and started to flash . It won't let me type in my password. what do I do?
Perform a "Hard Reset". This will restore your device to original factory settings. You will loose all your loaded programs and data loaded in Flash memory. The procedure is easily found in your Axim's Owner's Manual. :)
Posted on Mar 09, 2008
6ya staff
SOURCE:
How to bypass windows 7 Login with nothing third-party nor cmd
That will only work if you know the password first!
This information trust that you are the rightful owner of the laptop in question and software.
Close down and restart the laptop. When "Windows is loading" shows, press the power button to turn it off. Re start choosing Repair. When it can't repair, select Cancel and click on the arrow button. Load the last link at the bottom of the list. Open file and locate your local disc, the letters will have changed! Select all file types in the box and find system32. Find sethc. Right click and rename to sethc0.
Find Cmd now copy cmd and save as sethc.
Save and close down the laptop.
Re boot, when loaded press the shift 5 times a dos shell will open. Type after C:\Windows\System32> net user then press enter
If your user name listed is John, type after net user John *
spacebar between John and *
Press enter then enter again then enter again.
Close the dos window and press return you will be in windows with no password.
Jan 07, 2015 | Microsoft Computers & Internet
Tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 | Computers & Internet
I can't log in to my account on my Dell PC?
What program are you running, Is it windows 7 or windows explorer.
Apr 10, 2013 | Dell Computers & Internet
Now which operating system are you running ?
Forgetting your Windows XP login details might at first seem like a disaster. Don't panic though; your login password and username are easily recovered by changing the login details to that of the administrator.
Begin with your computer turned off, and then turn it on. You will need to log in to your computer manually and this can only be done in the load-up screens. Wait until your computer reaches the Windows login screen. The screen usually displays a "Welcome" message. Press and hold the "Ctrl", "Alt" and "Delete" keys two times at the Windows login screen. Your computer will automatically reveal a Classic Login box. Type "Administrator" (without quote marks) into the "Username" field and leave the "Password" field blank. Windows automatically creates an Administrator account when your computer is first booted up; in this account you can alter or change any user's login details. Navigate through the "Start" menu and click on the "Control Panel." In the Control Panel explorer, double-click on the "User Accounts" icon to open a new window. Select "Change an Account" in the User Accounts window and select the username you want to alter. From here you can edit the user's name and password, but you can also alter the user's picture, account type and .NET password. Restart your computer to login with your new username and password.
b>
How to unlock administrative password on acer laptop
I also forgot my Acer windows password last week.
I searched the solutions on the internet, at last I unlock administrative password with a tool called Windows Password Reset.
It just spent me 5 minutes to reset admin password.I found this usefull, you also can have a try.
Jun 10, 2012 | Acer Aspire 3502WLCi Notebook
HP 620 laptop shut down and won't start
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 24, 2012 | HP Computers & Internet
How do i transfer pictures from usb memory stick to computer
hello sir,
Open the folder where you have the pictures.
Insert the Flash drive.
Open the flash drive (using 'Computer' from the Start button).
Drag the pictures you want onto the flash drive window.
If it won't copy check the write protect switch on the flash drive (if it has one)
Godbless!!
Aug 11, 2011 | Computers & Internet
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
My bios password does not work anymore andi cant log onto the computer
remove the power cable from you cpu then remove the cmos battery and wait for few seconds then resit the battery and boot your pc,
post your findings for futher help
Apr 28, 2008 | Computers & Internet
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Dell Axim X51v Pocket PC Logo
93 people viewed this question
Ekse
Clive
Clive
Alun Cox
