Question about RCA F32632SB 32" TV
RCA TELEVISION THERE IS LINE GOING DOWN THE MIDDLE OF THE SCREEN. THE SOUND IS PERFECT.
    Problem Solver:
  • 17 Answers
Probably the HOT (Horisontal Output Transistor) has died. Take it to a repair shop. The parts cost should be in the range of 40-100 US dollars.
Posted on Jan 04, 2008
6ya staff
SOURCE:
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
Thin red line down the middle of screen
Enter muye 1 / 8 /3
it puts you into convergence mode and clears out all bad magic foces data.
then run perfect focus to save new data.
hope this helps
daniel
Jan 08, 2009 | Akai PT4298HD Rear Projection Television
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
Zenith d52wlcd 52in rear projection
How this is it? Is it perfect or is it like a blob of blue going down the screen? can you see the picture behind it or is there no picture in that area?
Sep 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Green line going down almost to the middle of the screen
Replace both convergence IC's STK392-110 X 2............T.
Nov 07, 2007 | JVC AV-48WP74 48" Rear Projection...
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
No Video
is the white line in the middle of the screen going left to right, if thats the case then sounds like a frame collapse, get it checked by an engineer
Feb 25, 2007 | Sony KP-48S35 48" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
