the small lights on when you switch?Try to switch the small lights together with the main light at the same time..If the small light will off when you switch the main light is meaning that the batery is too weak.Thus you need to charge,but your one problem is that it doesnt charge?Check the wire if it has cut or loosen connector.Most of the problem about charger is the wire itself due to a regular shagling or moving during a charge will perform.If the wire is good,next to check is the fuse.,Finally,if all these mention parts are good,you must check the Rectifier Diode if it is shorted.If not,then you need to replace the batery because the problem is that it is not charging,but it is not storing a power on your batery.
On the other hand,,if at the same time you switch the lights and the small light is still on but the main light is still doesnt work: check if there is a fuse and see if it is open,or check the main bulb itself because maybe it was opened too?
Was this helpful?
Yes
No
Popular Solutions for Black & Decker Black And
Black & Decker Black And Decker 2 Million Power Series 1365...
My snowblower stopped it self drive. The augger works fine but it won't move on its own. Any ideas...
(More)
My snowblower stopped it self drive. The augger works fine but it won't move on its own. Any ideas what the problem might be?
Instructions lost for rapitest wpp123. Will it locate nails so I can find the studs? I want to hang...
(More)
Instructions lost for rapitest wpp123. Will it locate nails so I can find the studs? I want to hang a heavy mirror on a stud wall. Better still where can I find instructions for it online?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
