The "audio-controller" is integrated into the Intel motherboard.
So, access 'www.intel.com' and follow the "Support" link to find & download & install the "audio" driver for your specific model of motherboard.
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card...
(More)
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card reader is dead. formatted and reinstalled windows xp hone on new hdd. can now use rear usb devices but still intermittent crashes. what do you suggest. I suspect moard fault. I would rather get a new moard with better specs, and use existing, very good, hardware. What m-atx board would you recommend. Thanks in advance, Paddy.
What is the part number of the 8-pin dip on the bottom of an IBM R51 27K9926 mainboard near the...
(More)
What is the part number of the 8-pin dip on the bottom of an IBM R51 27K9926 mainboard near the printer connector? It is marked 'Q4'. The only numbers I can make out are these 3 lines: f p46?? FDS ? 69 I am trying to fix the MB, not replace it. Thanks
I see the numerous posts identical to mine where eMachine will power on with light on mobo and HDD...
(More)
I see the numerous posts identical to mine where eMachine will power on with light on mobo and HDD clicks once, fans on, but no video and doesn't sem to POST. No acces to setup. This occurred after installing 1GB Crucial memory module (CT12864Z40B.16TFY, 1GB 164 pin unbuff DIMM 128x64 DDR) I tried it initially with original 256MB stick in slot2 but it wouldnt POST, so removed 256 and it came up and ran for 2 days but then refused to post again. I have replaced the PSU, same symptoms, but mobo 'looks' good. Due to the number of similar posts I am suspecting BIOS issues. Has anyone experienced same?
