Question about RCA P52926 52" Rear Projection Television
Rca projection i have an older projection that had a blown fuse (that i replaced) tv turns on but the picture is blurry & the top and bottom are bowed..and the picture seems doubled..any ideas on fixing it?
  • RCA Master
  • 8,617 Answers
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Posted on Jan 04, 2008
Fuse was replaced and the tv works but the picture is in 3d and the top and bottom of the picture is bowed and also somewhat blurry
This is a suggestion: if convergence is off does the label on the back of the set indicate this is a PTK195 Chassis?
If so I can tell you the likely bad part and how to find it.
Before you rate this information let me know what you find.
I am here to help.
Aug 13, 2011 | RCA P46924 46" Rear Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
Blown fuse
You have a focus control located on the right side bottom of the set. Try adjusting that. If that doesn't work you could have a flyback transformer going bad.
Jan 05, 2008 | RCA F35760MB TV
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
194 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
