Question about Albatron L17AS 17" Flat Panel LCD Monitor
Over range auto detectable flashes across screen
When i start up my computer the message over range and auto detect flash across he monitor.. then my screen goes blank
  • 81 Answers
Restart the computer in safe mode by tapping the "F8" key as it comes on. Then open display properties and set the display settings to a lower setting and restart the computer.
You
Posted on Jan 05, 2008
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
Jan 10, 2014 | FUJIFILM Instax 210 Film Camera
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Dec 04, 2013 | Elo Computers & Internet
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
When i start up my computer the screen is blank - its a polyview v17e. we manually must press menu on the monitor then move across to display settings and select analog - the screen then starts up? how do...
You may have to look at the setup menu to see if you can turn on 'AUTO SOURCE SELECT' and set to auto. You may have problem with the logic board that is why it cannot auto detect the DVI or VGA port automatically.
Mar 21, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Processing auto configuration keeps coming up on
First check to see that all of the cables are connected and fastened in tightly between the monitor and computer using the tiny handscrews on them at the monitor side and on the video card where it connects to your computer.
Also, the resolution detection circuitry in the monitor could be going bad, or you could have a bad video cable connecting it to the computer, or lastly, the video card in your computer could be going bad.
A few separate things you can try:
1. If you have a spare video cable, connect using the spare cable to the monitor and the computer to see if this corrects the issue.
2. If you have another monitor, I would connect it to see if you continue to have video issues.
3. Consider buying a new monitor.
Nov 30, 2017 | Gateway FPD1530 15" TFT LCD Flat Panel...
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Mirai Auto-detect blue screen
the VCO IF transformer has change value..,it need to adjust using plastic or wood stick,it is looks a metal cubes near the jungle IC or eles try to resolder the tuner
Oct 18, 2008 | Jensen TS2750J TV
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
Open Questions:
Albatron L17AS 17" Flat Panel LCD Monitor Logo
178 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
