Air Conditioners
Generic problem for all Air Conditioners
Wiring Diagram for Ruud Heat Pump
posted by NCITTech on Jan 04, 2008
Can you tell me where I can get the wiring diagram/schematic for my heat pump. Had a water problem and the diagram on the inside panel for the electrical connections. Need to know what the orange wire from the air handler (inside the house) connects to the thermostat and/or outside unit.
Jerry
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 16, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
you should give more data as;
Brand of the air handler, the condensor and the thermostat
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wiring Diagram for Ruud Heat Pump:
I don't want to Accept this solution
Solution #2
posted on Oct 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
mknopmnimnae
Thank You!
Can you Help with these Air Conditioners problems?
Air Conditioners
My furnace will not stay lit. It lights for about 5...
Air Conditioners
I need a valve for a Endless patio heater 233000, do you...
Air Conditioners
Amana Gas furnace, Air Command 80 SV. Does not ignite. ...
Air Conditioners
My high pressure sodium lamp did not work after replacing...
Air Conditioners
i have an older coleman furnace it has electric ignition ,...
Loading problems.
Repair Service
Find Air Conditioner Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Air Conditioning Contractors
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
