the screen of my sony vaio disappear when i open it in normal mode....but i can open it through safe mode... how can i resolve this? if i will reformat it, will i lose everything? and need to buy a new operating system?
if you reformat the drive then you will need an operating system to put back on ... but you likely dont need to do that ... since you can open it in safe mode then you probably have a driver messed up on the hard drive ... in safe mode you can do a system restore .. this will set your system back to the state it was in before the problem happened .. thats
start, all programs, accessories, system tools, system restore (may vary depending on your operating system) .. if restore doesnt work then you should reload your drivers .. like video, sound , motherboard and such .. those are likely available for download from sony .. .. there are lots of things you should try first .. reformat as a last resort .. once you get the thing going then you might be able to make a systems disk .. instead of giving you a DVD with windows on it, they often provide that system hidden on your hard drive ... you can sometimes make your own recovery disk from that ... if you had a windows disk for your machine then you could repair your system with that without having to format .. .. sometimes there is a special key combination that will restore you system to its original state .. but you might loose everything in doing that unless things are backed up ... in fact since you are able to use safe mode then it would be a good idea to get a jump drive and put anything important on that while you can ..
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO VGN-FZ320E/B 15.4"
Sony VAIO VGN-FZ320E/B 15.4" Notebook PC ( Intel Core 2 Duo...
guys....i got problems with my webcam.i download my driver cyberlink youcam 3.but when i install...
(More)
guys....i got problems with my webcam.i download my driver cyberlink youcam 3.but when i install it.it writing ''no webcam detected.try plugging in a webcam into your computer now.if you are using an integrated camera,make sure that it is turned on.'' but all i know is laptop webcam cant be turned on and off.so can someone of u outside there help me....
The machine wont go further than the swirling circle after logging in. I was told by the tech...
(More)
The machine wont go further than the swirling circle after logging in. I was told by the tech support I would need tomreset to factory settings but then it worked. I dont have disks so will need to transfer to a USB
how do i use my delstar netbook i got this for my daughter and we are use to regular computer and...
(More)
HOW DO I USE MY DELSTAR NETBOOK I GOT THIS FOR MY DAUGHTER AND WE ARE USE TO REGULAR COMPUTER AND THIS IS NOT COMING TO US HOW TO USE IT
How do I connect to the internet. It won't connect after I click connect. I have one of those...
(More)
How do I connect to the internet. It won't connect after I click connect. I have one of those Delstar netbooks
