GE GSS22JF Side by Side Refrigerator
Problem for GE GSS22JF Side by Side Refrigerator
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
By ccoobs on Nov 05, 2009
A few days ago, we noticed that the ice cube dispenser was not dispensing ice (though the 'sound' of the ice dispenser still worked when you depressed the lever to get ice and the water dispenser still worked). We then discovered that the ice cube bin was filled with one solid block of ice (indicating the ice cubes had thawed and refrozen into one large chunk).
We thawed the bin out and put it back. Ice cubes were made and dispensed successfully. Today, though, a couple days later, the ice cube dispenser and water dispenser do not work at all, even after completely removing the ice cube bin. When you push back the lever to dispense either ice or water, no sound is made whatsoever and the little green LED light above the ice & water icons fades to black. A moment or two after releasing the dispense lever, the light will come back on.
Additionally, there seems to be a whirring sound emanating from the lower portion of the back of the left (freezer) side. When you try to dispense ice or water, that sound goes off. A moment or two later, that whirring will come back on (in synch with the LED light).
What's wrong?
Thanks!
Cory
Solution #1
posted on Nov 05, 2009
Not Rated)
EllaWatson25
Rank: Wiz  GE Refrigerators  Expert
Rating: 84%, 110 votes
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Was this helpful?
Yes
No
Popular Solutions for GE GSS22JF Side by Side
Questions and Unsolved Problems for GE GSS22JF Side by Side
Do you recommend GE GSS22JF Side by Side Refrigerator?
Answer
Answer
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced... (More)
Answer
my g.e. tbx 21tkc fridge, only gets 20 degrees in the freezer and 50 in the fridge, i replaced the... (More)
Answer
How much did it cost to have the motherboard, heater, and thermostat replaced for the GSS22UFPA... (More)
Answer
GE model GSS22JEPH Have to turn water off at valve behind appliance.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE GSS22JF Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
