To diagnose this the fan relay is the place to test. The relay is conceptually two circuits. One high current circuit and one low current circuit. The concept is that the temperature sensor tells the computer that the temperature requires the cooling fan to come on. The computer then either grounds the low current circuit or feeds it with voltage. This closed circuit then completes the high current side of the relay, which runs the fan. So your fan continues to run for one of two reasons. 1. If you find that the low current circuit is open (meaning no current flow), yet the high current side is still closed, then you have a bad relay. 2. If you find that the low current circuit is closed, it is because the temperature sensor is bad, causing it to tell the computer the engine needs cooling after the temp drops below the range when cooling is needed...Is this expensive to get repaired? I tried looking up cooloing fan relay at Advance Auto got no results does it go by another name?
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the...
(More)
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the cooling! fan runs ok. Have got it half pulled to bits...problem seems to be in the cooling motor/ compressor if it has one!
my 1995 jetta started smelling hot thermostat guage in car seemed to be working fine.Then water...
(More)
my 1995 jetta started smelling hot thermostat guage in car seemed to be working fine.Then water check light came on, couldnt find radiator noticed over flow was steaming. Went to remove cap boiling water and steam shot out. Drove car on freeway with heat full blast to try and get car home did now temp gauge says normal still boiling and blowing cold air only. please help
we are getting codes C7 and C8 with a 76 number. The hot water does not come on, but if you turn the...
(More)
we are getting codes C7 and C8 with a 76 number. The hot water does not come on, but if you turn the breaker switch on and off it sometimes starts working again
