Question about Fahrenheat LFP6152 Halogen Baseboard Heater
Question about Safety
I need to know if the above baseboard heater is safe for pets and children. I have 2 very little girls, and need to know they won't be burned or hurt. Can you let me know?
  • DanaArms Jan 05, 2008
    You have issues "hung". Obviously you don't have kids, or, you could care less if you hurt them. I really want to know the specs of this and I don't appreciate you making dumb comments that aren't helping what so ever.
    Problem Solver:
  • 18 Answers
After they find out it hurts they will stop automatic.
Posted on Jan 05, 2008
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Nov 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
Jan 29, 2009 | Fahrenheat FBE15002 Baseboard Heater
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat LFP6152 Halogen Baseboard Heater Logo
73 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
