I have a Mitz. rear-projection WS65869 TV, the blue conversion line with come come over to line up with the white. Any suggestion on getting the blue to come over and line up? We have already tried with the remote. Thanks!
WS-65869 USES a single STK-393-110 convergence IC.
If convergence if off and either blue or red will not adjust in some direction--The chip and any of the 3.9 ohm resistors around it that protect it--will need to be replaced if they are bad.
Most of the time--just the chip needs to be replaced and the set adjusted.
I have step by step, start to finish instructions for this repair in this type of set.
If you can do the repair, total parts cost will be under 25 dollars--you can buy the chip on Ebay and the resistors are easy to check.
I have photos of the resistors and the instructions tell you everything you will need to do the repair.
If you cannot do the repair--most shops are going to get 300 or more for it---if you go that way make sure you get someone to do it--it should be able to be done right in your home--takes about 1 hour--I know as I have done HUNDREDS of these sets with this problem.
If this information helped you rate this solution as I do this here for free.
If you need the instructions let me know and we will find a way to get them to you....
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi WD-62525 62 in.
Mitsubishi WD-62525 62 in. Rear Projection HDTV Television
The picture on my wd62525 started getting blurry then the tv shut off and the red light started...
(More)
The picture on my wd62525 started getting blurry then the tv shut off and the red light started blinking. Bought a replacment bulb on ebay and changed the housing and installed it. The tv had an osram bulb this is a philips AM 0000893/338ZN41A/03960J9, supposedly a direct replacement. Red light is still blinking, tv does not come on. Did not touch bulb, when i reset the tv and turn it on i can see the bulb come on from behind the tv then it turns off.
i have a 7 year old rear projection 62 inch mitsubishi hdtv that has a dark and dim picture. any...
(More)
i have a 7 year old rear projection 62 inch mitsubishi hdtv that has a dark and dim picture. any thoughts
My tv blinking light 2 days and I reset the system and have the same problem. My tv is wd62725...
(More)
My tv blinking light 2 days and I reset the system and have the same problem. My tv is wd62725 Mitsubishi. I disconnect my tv and connect and have the same problem. \ Nestor
mi pregunta es sobre q mi tv se le fue la imagen la resetie y se activo el foco q decia q el...
(More)
mi pregunta es sobre q mi tv se le fue la imagen la resetie y se activo el foco q decia q el problema era la lampara despues se puso q era el status y ya no quiso ni prender q puedo hacer me puede ayudar
How do I know for sure I need a lamp replacement for my Mitsubishi DLP projection TV? Could it be...
(More)
How do I know for sure I need a lamp replacement for my Mitsubishi DLP projection TV? Could it be another issue or problem?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
