Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | You can hear furnace run...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
You can hear furnace running but the blower never
By lindacoleman on Nov 05, 2009
you can hear furnace running but the blower never comes on.
Solution #1
posted on Nov 05, 2009
Not Rated)
hmlee390
Rank: Guru
Rating: 91%, 129 votes
do you mean the inside blower or the outside unit blower ... actually the problem might be a similar part in either case ... the blower motor has a capacitor mounted on it or near it ... it will be marked something like 160 uf at 200vac or similar . it will have wires attached or plugged into it .. the capacitor is what gives the blower motor a signal to tell it which way to start turning ... once the blower is running then the capacitor is no longer needed ... its only used to get the motor started ... if its bad then the motor will hum but wont turn .. if you manually spin the fan then the motor will take off in the direction you spun it (dont get hit ) .. a new capacitor is not expensive .. you need the numbers off the old "starting" capacitor or just take it with you to the parts place to match it up .. you may be able to order it from Ruud ... a HVAC repair person would likely be able to bring one with him for repair if you give him the numbers off the part or the model number of the furnace .. make sure the blower turns freely by hand (with power off) .. if not it may need bearings lubed .. ..
Was this helpful?
Yes
No
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
