Question about Sony Cyber-shot DSC-W55 Digital Camera
Always in Movie Mode
It seems that the camera is always in movie mode even when I am just trying to take a regular snapshot. I have even changed settings and it continues to have the same problem. I get a large "RECORDING" across the screen in red letters.
You have to put it on auto adjustment( green Camera) then push the menu buttion and then slect normal and it should work!
Posted on Jan 05, 2008
I tried contacting the Nikon tech support,infortunately they were unable to answer my question.The D5000 has a movie mode; with the camera came a 'pq1 4GB SD HC card'.According to the manual I can...
The five-minute limit has nothing to do with the memory card or the video resolution. In some parts of the world video cameras are taxed at a higher rate than still cameras. Cameras that can only record videos up to five minutes in length are not considered video cameras and thus are taxed at the lower rate.
When was the last time you saw a movie or TV scene that was five minutes long without any cuts or breaks? It doesn't happen often and very few people find the five-minute limit restrictive.
Video quality is a very subjective thing. The quality is better than that of almost all compact still and video cameras. It's not as good as professional-quality video cameras. Video has a different "feel" from film --- but which is better?
Since the recording length doesn't depend on the resolution, I'd suggest you always record at the largest resolution. Videos can always be shrunk in size --- they can't be expanded.
Aug 17, 2011 | Cameras
Sony dsc-H1 won't switch off of movie mode
When you switch the camera from mode to mode, does it make the click noise to signify that the camera recognized that it changed modes? If not it could be that the switch itself has become unlogged from the switch. I know I had a older camera had this happen before. Try pushing down hard on the toggle wheel and seeing if it will snap back into place. Otherwise the switch inside the camera itself is probably broken, and if this is the case cheapest thing you can do is have Sony do warranty work on the camera. Click repair and service under Technical Support. This will get the process started on the warranty work.
Aug 25, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Mar 11, 2017 | Canon PowerShot SD1100 IS Digital Camera
Camera not turning off and when ON,always in picture preview mode
This is a problem on the motherboard, sort of like a solenoid that controls the functions of on/off mode and video still mode. it needs a service and possibley a patrt replaced Hope its unjder warranty as it expesnive
Jun 23, 2009 | Canon PowerShot S3 IS Digital Camera
Can't change settings on movie option
To change movie resolution:
1. Set control dial to movie mode
2. Press the Func/Set button
3. Scroll down to the recording pixels icon (probably 320 on yours right now)
4. Use left/right arrow to select 640
5. Press Func/Set button
May 23, 2008 | Canon PowerShot G7 Digital Camera
Stuck in movie mode, but won't record
internal microswitch connector has been it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Digital camera
There is tiny place with the wrighting of "C1220" - pull it out and put a new bat. all be solved
Dec 15, 2007 | Cameras
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
Lens is not opening in the movie mode,unable to record movie also.
normally there are two possible causes for the problem, 1) the connectors of the rotary switch are dirty or not making proper contact. 2) the cable from the rotary switch is damaged. In both the cases you have to get the swith changed.
Nov 01, 2006 | Nikon Coolpix 3200 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
