Panasonic PT-47WXC43 47 in. Rear Projection Television
Problem for Panasonic PT-47WXC43 47 in. Rear Projection Television
Television won't turn on and the power light
By webaldwin on Nov 05, 2009
Panasonic 47" rear projection television won't turn on and the power light blinks 3 times. No display.
Best Solution
posted on Nov 05, 2009
Very Helpful)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 1177 votes
98% OF THE TIME 3 blinks (which is short protection) means one or both of the two STK-392-110 convergence IC's is shorted.
Both chips along with any of the dozen or so 2.2 ohm blue resistors around them that are bad need to be replaced and the set adjusted.
You can buy a pair of chips on Ebay for less than 13 dollars plus shipping.
I have start to finish, step by step instructions I can post here if you are able to do the repair yourself.
I have a set tomorrow very much like yours I am going to go repair--same problem. Most shops get 300 or more for this repair--It takes about one hour and should be able to be done right in your home.
If you get someone to do this repair---make sure BOTH chips get changed or you are going to have the same kind of problem in a few months.
If you want the instructions let me know and I will post them here for you.
If this information has helped you rate this solution and understand I do this here for free.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Great advice and very fast response! " - webaldwin
Solution #2
Somewhat Helpful)
rusty_etech
Rank: Guru  Televisions & Videos  Expert
Rating: 91%, 141 votes
You have a horizontal/high voltage problem. This is a dangerous circuit so you should have a repair shop check this out for you. Thanks
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-47WXC43 47 in.
Questions and Unsolved Problems for Panasonic PT-47WXC43 47 in.
Do you recommend Panasonic PT-47WXC43 47 in. Rear Projection Television?
Answer
Answer
my panasonic projection tv stopped working. the red light stays lit when turned on and it makes that... (More)
Answer
already replaced the convergence chip and resistors in our panasonic rear projection tv but now... (More)
Answer
I have two issues with the picture on my screen. 1)There is a red tint on the screen. I've tried... (More)
Answer
I have a panasonic tv PT 4743 that turns on and than sounds like it is shutting off and than I get... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
