My Oasis washer fills fine but when it gets to the agitate cycle it skips that and the time drops to the drain cycle and then leaves an "oL" on the timer screen. Not sure what this is. Please help.
Did you find a solution to your problem? We are having the same exact problem with ours. I lightened up the load and still does same thing. It jumps from 30min after fill to 5min drain. Drain and spin works but its skipping the wash cycle.
It means over load. that could mean a few things. what you should do is grab on to the tub try to turn it. if it feels like take some force to do there is something stuck around the shaft of the washer. the only way to actually check is to pull the tub. to do that need to remove agitator. under that should have 6 philip screws pop the lid open with a putty knife in front youll see clips holding the lid down. after that the tub can be removed. sometimes it take some force to remove
