Question about Brother IntelliFAX 560 Plain Paper Fax
Installing paper I am having a problem install or replacing the plain white paper in the fax machine it was a gift to me. can you tell me step by step on putting the paper in the machine. I think that the peace that the paper hook onto is missing or is there a bar that goes in the machine to hold the white paper. do the paper just lay inside of the machine. I am so lost
  • 417 Answers
Some machines have a lever on the side where the paper goes I'm not sure this one does but if it does pull the lever towards the front of the machine load paper then push lever back then you are done.
If the machine hasn't got a lever then some machines will need the start button or stop button to bee pressed after the paper has been installed.
Hope this helps you
Thanks J
Posted on Jan 06, 2008
6ya staff
SOURCE:
What value to set in set ink cnt?
At MaybeNow online guides are always there to provide technical support to troubleshoot Canon FAX-B840 Plain Paper Bubblejet Problems which is free of cost. You can also get Canon FAX-B840 Plain Paper Bubblejet, Fax Machines Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 30, 2010 | Canon FAX-B840 Plain Paper Bubblejet
Fix the fax machine
You have installed a defective toner cart. Many bad ones out there
Jun 08, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Error 011
Where is the broken left tab. Sometimes on that cassette the tab breaks that tells the unit that the paper cassette is installed. If this is the case then the tray has to be replaced.
Nov 06, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Rec'd in memory - change cartridge - install BC-21e
No, all cartridges must be installed and have ink in them.
Oct 28, 2008 | Canon FAXPHONE B740 Plain Paper Bubblejet
"DARK PAPER USED" Message
I found a copy of the manual, and on page 202 the "Dark Paper Used" message can be caused by three things:
1. Paper used is colored or stained -- replace with clean white paper.
2. Paper was pulled from machine before the fax was ejected completely.
3. The received document support is not installed correctly. Page 3 in the manual shows this support as the rear-most, and it looks like it should be installed with the upright portion angling toward the rear at about a 30 degree angle.
Sep 02, 2008 | Canon FAX-B160 Plain Paper Bubblejet
PANASONIC KX-FM386CX DRIVER NEEDED
Kindly help me to down load install this machine
P K Kutty
May 01, 2008 | Office Equipment & Supplies
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
50 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
