Question about Technics SL-BD22 Turntable
No Sound out of Left side
The left channel does not produce sound anymore - well to be more accurate: it's very, very faint with a lot of low end hum to it.
I've checked the stereo itself, the speaker cable, and the speaker - they all work fine.
Anyone have any ideas? Thanks so much
  • czimmerma Oct 15, 2008
    I can only get sound of one speaker when using the record player but not with the CD player etc going through the same amp. I don't know what the RCA things are mentioned in another answer.
    President:
  • 4,402 Answers
Is it possible to swap the left and right wires on the needle cartridge? does the sound change sides? if yes bad cartridge if you still only get sound from right side try changing around the rca phono plugs
Posted on Jan 04, 2008
Only one speaker working
pls. identify w/c channel is working then try switching the speakers, check your rca cords from your source player, try to switch them. th
May 05, 2013 | Integra DTR-9.1 7.1 Channels Receiver
Th-42pd25 humming sound and faint picture
Sounds like an inverter transformer humming, not producing enough current to display a bright picture. Check the caps in power supply, next to the plug where it says 24v and goes to the inverter board on the left side of tv. Or check for bad connections on inverter transformers on inverter board, Thanks
Nov 11, 2011 | Panasonic Televison & Video
The left main channel not working. hook any speaker to it and putting my ear close, it has a very low hollow sound, almost a hum. would there be fuses, a reset, or something on each channel or something...
There is no seperate fuse but it seems likely that the left side preamp or the power amp section had opened up a fusible resisitor that could have shut the section.
Now the only way out is to take a voltage or signal test with the right - working- channel as a reference . Please attempt only if you are familiar if not it will end up with further damage as the sections are very delicate. Testing with a signal will confirm the faulty section to narrow down your search.
Aug 23, 2011 | NAD T742 Receiver
I believe I have lost the left channel on my GII. Is that a common difficulty? How can I verify that is the problem? I've had this unit for 7 years. Right channel continues to pump out sound and...
No just the cartridge perhaps! First disconect the wires to the cartridge. With the amp on. Touch the end of the wires one at a time (don't worry you won't get a shock). On two of the wires you should hear a hum on each channel (one for left one for right). The left channel should hum. If it doesn't it's not the cartridge, but either a faulty lead or the left phono pre-amp is faulty on your amp. Test the amp by putting the right in the left channel.
If the left hums the cartridge is faulty.
Jul 24, 2010 | Gemini SA-600 II Turntable
Only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
On my Mag Innovision model 700 P lcd monitor, the integrated right side speaker does not produce any sound. In XP control panel I do have both left & right speaker set to max.
On the plug to the computer sound card, is the plug completely inserted? The end of the jack is for Left channel and the right channel is only fed if the plug is fully inserted.
Nov 08, 2009 | Mag Innovision InnoVision DX 700T Monitor
Faint to loud humming noise while driving and turning...
Could be either a loose belt or you are low on power steering fluid,or the power steering pump could just be worn out.
Aug 20, 2009 | 2006 Chevrolet HHR
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Technics SL-BD22 Turntable Logo
354 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
