Question about Sony DAV-C770 System
Stereo to 5.1?
I want my stereo input, plugged into video 1, to come out of the front AND back L and R speakers.  Can it be done? -John
When you switch your Sound Field to 2 Channel it should use all the speakers (although you'll notice it doesn't sound as loud as normal coming out of the center speaker). Auto Deco actually sounds good in this mode, in my opinion.
Posted on Jan 28, 2008
No video or sound
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 27, 2011 | Nintendo Super NES Console
Tip
How to connect my iPod to an Amp & Subwoofers
<p>If your iPod to your amplifier or subwoofer that connects to a stereo receiver. This can be done through an additional cable. <br /> <p><br /> <p>1. Locate the auxiliary input on your stereo connected to your amplifier and subwoofer. These entry, small and round is labeled "AUX". Usually this entry is available in front of the stereo, but some devices can be found on the back. <br /> <p><br /> <p>2. Connect another cable to the auxiliary input of your stereo. <br /> <p><br /> <p>3. Connect the other end of extra cable to the headphones of his iPod. <br /> <p><br /> <p>4. Press the "AUX" input button on your stereo. Now when you play a song on your iPod you listen to them on your speaker system including subwoofer and amplifier. <br />
on Aug 09, 2011 | Apple iPod touch
I want uninstall the audio of my hyundai 1996, I need knowing that color is the positive and negative
Car Radio Constant 12V+ Wire: Red/Yellow
Car Radio Ignition Switched 12V+ Wire: Blue/White
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4?
Front Speakers Location: Doors
Left Front Speaker Wire (+): White/Red
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): White/Blue
Right Front Speaker Wire (-): Black/Blue
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): White/Red
Left Rear Speaker Wire (-): Black/Red
Right Rear Speaker Wire (+): White/Blue
Right Rear Speaker Wire (-): Black/Blue hope this helps
Feb 11, 2011 | Hyundai 1991-2002 Wire Harness
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Jan 10, 2011 | YouTube Videos
My wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jul 31, 2010 | 1990 Toyota 4Runner
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Do not have a sub output on receiver /do not know which wire to plug into the amp sub input/5 channel amp /have rca output for front and rear speakers
Hello southernbike,
With a 5-channel amp (stereo L/R front, stereo L/R rear, and subwoofer) you only need the two pair of stereo inputs.
You do not say which brand and model of amp you have, but most have an output configuration similar to the Alpine shown in this link. Connect the front and rear RCA's from your receiver, your vehicle speakers to the respective output terminals, and your subwoofer to the 5th channel terminals.
Hope this helps.
Jul 29, 2009 | Dual Car Audio & Video
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Sony DAV-C770 System Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
