Garden Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removed bolt but still can't remove rear wheel on MTD riding mower .
itsman
Level 2:
New Friend:
  • Expert 89 Answers
  • Posted on Nov 05, 2009
itsman
Expert
Level 2:
New Friend:
Answers
89
Questions
Helped
32087
Points
181
They sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
  • chloedog2 Oct 26, 2010
    Explain more about the two holes on the rim if you could. Go into more detail if possible.
Remove rear wheel mtd 115/30 ride mower
Remove bolt or bolts and you will have to pry it off if you have not removed them before but be careful not to bend anything.
Jun 30, 2018 • Mtd Garden
How do l remove both rear wheels from a mtd lawnflite mower
depends which model,but undo the 1/2" bolt in the centre of the wheel and slide wheel off axle. However by experience i know that if the axles havent been removed and axles greased regularly then you will have trouble getting them off, You will need to spray wd40 or similar dowm the axles and then jack up rear of machine, get a block of wood and a big hammer and knock the wheel from the inside while sprying wd40 onto the axle every time the wheel moves a bit
Feb 17, 2015 • Mtd Garden
Mtd riding mower steering shaft is stripped out model 13AN673G131?
not something easy to do... there is a bolt in the bottom of the shaft. there is a steering wheel that has to be removed. then the shaft lifts up and then you tilt it as you are sliding it out... heed my first statement
Aug 29, 2014 • Mtd Garden
2answers
Remove rear wheel
What is stuck? The bolts? The wheel is stuck after removing the bolts?
11helpful
Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
2answers
Can't get the wheel off of a yard machine lawn mower
im having the same issue, model number: 13am675g062
serial number 1j148c30188
3helpful
How to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
1helpful
Hi Folks,
Try using penetrating oil and soak it up good tap the inside easy a few times hopefully it will break loose.
Mar 16, 2009 • Garden
REAR WHEEL REMOVEAL
it depends on which style mower most ayp (poulan craftsman husquvarna....) are put on with a e clip they may become froze to it but can be removed. now most mtd (yard man yard machines bolens troy bilt...) have a revers thread bolt with a tapered shaft trust me i worked on theses for 10 years. why would you want to take it off anyway? everything can be done with it still on
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
