hello. problem with the audio (AUDIO), unit goes to standby and blinks the
self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some
projection models of Sony TV sets, this code means that T8005 (flyback
transformer), or the associative components in the high voltage
circuits are defective on the D board.
my kp46wt510 has a red shadow to the right side of any image. Also the convergence mode will not...
(More)
my kp46wt510 has a red shadow to the right side of any image. Also the convergence mode will not respond the plus will not move like it use to
hi, i have a 60 inch projection sony tv, from circa 2000, tv is fine but it seems as though the...
(More)
hi, i have a 60 inch projection sony tv, from circa 2000, tv is fine but it seems as though the remote has stopped working, and not just the remote, but whatever the sensor in the actual tv itself, as the tivo remote wont control the tv , nor am i able to program ANY remote to run the tv... i guess my question is where is the sensor located? is their a way i can reset or replace or otherwise confirm what i expect? and has anyone heard of this before?
Sony KP-57WS510 has double images on the left side. You can see the red and green images split on...
(More)
Sony KP-57WS510 has double images on the left side. You can see the red and green images split on the left side of the tv screen. I have had the TV for at least five years. The double image is mostly on the middle bottom left while the right side is fine. The double/split image is worst when you play a dvd require HD quality.
