Eureka 5893AVZ Bagless Upright Cyclonic Vacuum
Problem for Eureka 5893AVZ Bagless Upright Cyclonic Vacuum
The handle for my Eureka 5993 AVZ was getting very
By ericapp on Nov 05, 2009
The handle for my Eureka 5993 AVZ was getting very hot when used. Finally, the wires around the switch melted and now the vacuum will not work. What is wrong? Is the switch bad? The wires only melted in the immediate vicinity of the three-prong switch. Nothing else appears to be wrong; the vacuum worked fine when it was running - except for the handle getting hot.
Thank you!
Solution #1
posted on Nov 05, 2009
Not Rated)
tvservice306
Rank: Wiz
Rating: 80%, 91 votes
try cleaning all...
if have sam paoblem need replaced main motor....
Was this helpful?
Yes
No
Popular Solutions for Eureka 5893AVZ Bagless Upright
Questions and Unsolved Problems for Eureka 5893AVZ Bagless Upright
Do you recommend Eureka 5893AVZ Bagless Upright Cyclonic Vacuum?
Answer
Answer
The handle was getting hot and we opened the handle and the wires were melted around the switch. I... (More)
Answer
eureka 5893avz 4d vacuum brush motor will not run. Push reset botton doesn't start. where can I get... (More)
Answer
I change all filters and it still cuts off after about 10 minutes. No dirt or dust has been **** up.
Answer
Okay, what happened is I was vacuuming one day and something must have been sucked into the vacuum... (More)
Answer
vacuum shut off while in use. almost new. now it won't turn on. other outlets work so not a breaker.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eureka 5893AVZ Bagless Upright...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
