Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Beko dishwasher fills with water, does not wash but will drain the water away
Turn on dishwasher, dishwasher fills with water, dishwasher does not wash, spray arms do not get wet, do not move and they are clear and unclogged at the end of the cycle the water drains away. My dishes unwashed.
  • Anonymous Jan 19, 2008
    my problem is the same
Impellor buggered. Needs replacing
Posted on Apr 12, 2008
Beko d 4543 bi
Lift the outlet pipe from below the water line outside or in your drain pipe.
Oct 07, 2017 | Dishwashers
I have a Beko DE 2541F Slimline Dishwasher and it fills and empties the water but the cycle does not start. The water does not get to the spray arms. I have tried on pre wash cycle as well so I do not...
If there are no problems of drain valve stuck, then the problem with the micro controller board.
When the water is full in the tank, the wash cycle will start with the spray arm in action. Lastly block the drain hose and see. Here water full will be detected & the machine will start if the level sensor is OK .
If m/c works here, you have to check the Solinoid valve of the drain.
Otherwise the micro controller.
For this pl take the help of the service provider as lot of programming versions are there. Some may suit or may not. If we try the will not accept after selling the board to u.
Apr 07, 2010 | Beko 24 in. D3731F Free-standing...
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Beko washing machine fills with water when not in use!!
hi got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
hi there.......this problem could be caused by a failed heater element ...if the element is not heating the machine will just wash wash etc...the front panel will have to be removed to check the heater element....if the element is ok...check the heater NTC ( little white plug in the heater element)...if all ok here....then you have a main PCB board failure....
it may be more economic to have beko send an engineer to you...
regards Sir Galahad
Nov 03, 2008 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
check that there are no kinks in the drain pipe or that the pipe way is clear.
Thanks J
Oct 23, 2007 | Beko 24 in. D3421F Free-standing...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
1,029 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
