Panasonic Lumix DMC-TZ1 Digital Camera
Worth fixing???
shared by 4 users
posted by efarr on Jan 04, 2008
I have had this camera for 1 1/2 years.   It makes a grinding, buzzing noise when turned on all the time UNLESS I am using the zoom.  The noise quits while zooming, but continues as soon as the zoom lever is released.  Other than this constant annoying buzzing sound, it works fine.
Thanks for your advice,
Ed Farr
efarr4@hotmail.com
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by Guest on Sep 27, 2008
same problem..
Posted by Guest on Sep 24, 2008
I droped my camera and it makes a grinding noise like trying to focus. It sill works fine but makes alot of noise. Is it worth fixing?
Posted by heatherlia on Jan 25, 2008
My camera's got the same problem. It's weird because i didn't do anything to it (drop it, hit it, etc) it just started making this noise one day when i turned it on. Ive discovered if you shake it a little bit the buzzing will get quieter and occasionally stop. However, as soon as you set it down, it starts up again. ALSO, I've noticed that if your uploading pictures, and turn it on while its in the "review pictures" mode, there is no noise. I think something may have gotten stuck in there, or mine at least.
Can you Help with these Digital Cameras problems?
When I try to e-mail a picture it asks for the default...
pictures are real grainy, any ideas?
i was zipping along taking pictures, and when i tried to...
I'm referring to the Panasonic Lumix DMC-TZ! model. Not...
After 2 years of reliable use, my TZ1 flash is out of sync...
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
