Question about Black & Decker BL1900R Blender
Replacement parts I need to order a replacement part. The part is the bottom portion the blade, washer and plastic screw on part. Please let me know how to get it.
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Posted on Mar 24, 2009
Look in local craigs list under for sale - household and find an equivalent blender , get the jar - enjoy cooking !!!
Posted on May 23, 2009
6ya staff
SOURCE:
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
I have the cuisinart SPB-7 Smart Power and it leaks. I put my milk in and it run on the counter top. What do I need to replace? Is it the washer?
The bottom part that screws on the jug with the blades, either the o-ring is bad,or the screw on piece is cracked and needs to be replaced.
Mar 17, 2011 | Cuisinart SPB-7 SmartPower Work Top...
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
Sep 12, 2008 | Oster 6803 14 Speed Blender
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Black & Decker BL1900R Blender Logo
1,941 people viewed this question
Top Black & Decker Blenders Experts
Marvin
Marvin
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
