Question about Gateway GTW-P42M303 42 in. Plasma Television
Remote Control Sensor
Remote control appears to function but TV will not respond. I assume the sensor is not functioning based on info from tech. Is the sensor a replaceable module? If so part number, part availability and price? TY
  • Gatewayed Jan 07, 2008
    I've been had!! Does a TV manufacturer with integrity exist? Any recommendations? -Gatewayed in the backside!!!!!!
  • Anonymous Mar 09, 2008
    Also have same TV with same problem... the remote seems to work (red light goes on in remote when pressed) but nothing happen on TV and also tryed to use an universal remote. Just wandering if will be a waste of time and money to call a TV repair tech!
Had the same problem and had to replace the image board to get remote functions to work. I scoped it all the way to pin 80 on the micro. I now have my remote functions again. Hope it helps.
Later Pudgi
Posted on Nov 02, 2008
U have to rape ur mom and then shuv it uo her ***** k? did that help. if youre thinking im joking then im not bvecause the juice from the fanny rehydrates the remote and make it hyperacvtive and gives it the strength to work one again. and... i like girls :)!
Posted on May 12, 2008
I have an audiosonic km2120. This has recently been starting to not respond with both remote or buttons on TV. So is currently unusable. Any answers to this please?
In case of front panel buttons not working:
Check whether the Panel Lock function is activated. If this function is activated [ON]' panel buttons won't work. Check it. Refer its user manual for details.
In case of non-working remote control:
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 09, 2014 | Televison & Video
Camera user
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
You should make sure about the remote controls' function first, before assuming that the sensor inside the TV to be faulty. Check it first and proceed. One among the posts with the site have all details about how to check a remote control.
Apr 17, 2014 | Sanyo Televison & Video
Today the tv remote just stopped working.No off/on,No reaction of any button.batteries are fine.TV only works from the side panel.Idon't know where the remote sensor is located on the tv to clean it...
To confirm if the remote control has been working fine, point directly the infrared emitter to your cellphone camera, while pressing any button key at the remote control, you will see the flash of an infrared indicating that the remote control has been working. Click this LINK for more info.
Let me know if you see the infrared flashing.
Jdvillanueva
Jun 12, 2011 | Televison & Video
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
Remote control-function stopped working. After...
Yes the VCR remote sensor is faulty. It will most likely be the IC, which can be found by tracing the wiring from the detector on the front of the vcr.
May 21, 2010 | Mitsubishi HS-U577 VCR
Non-functional remote control for Baseline DVD recorder
Hi:
No do not try soldering the led. This is a led (Light Emitting Diode) It is supposed to look like that. You might have a bad IR sensor in the Recorder itself. The Ir sensor (Infared Sensor) receives commands from the remote and relays the command to the microprocessor in the recorder for processing. To make sure its the remote try a universal remote and program it for your dvd recorder and see if it takes commands of any sort. IR sensor are very cheap the only issue is installing it on the main board of the recorder.
Dec 02, 2009 | Televison & Video
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
Not functioning on my tv sensor
need nmore info then that. are u saying that the remote control is not working with the tv or are u saying that the controls on the set is not working . ok lets say the remote is not working 99 times the problem is the remote control unit. the best way to find out is. if your tv is a newone 1 -2 years old u could take the remote to best buy and see if it will work on a nother tv set there. if not it is your remote problem solved.if it does work then i could be the sensor but u need a scope to see the rf signal from the sensor i have only change 2 sensers in my 30 years working in electronice service field. let me know marty
Oct 13, 2008 | Televison & Video
Gateway GTW-P42M303 42 in. Plasma Television Logo
495 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
